94 dakota 2wd no overdrive
94 dakota 2wd no overdrive (SOLVED)thx guys
Hello everyone im new to the forums i just bought a 94 dakota 2wd 5.2l and my overdrive does not work. now i have spent like 6hours reading threw these forums for solutions. tried a couple and no luck so here is my question im missing the buzzurd module from the fuse box do you guys think that could be related? i saw a couple wiring diagrams and looks like the overdrive is connected with that module? but i could have read that wrong. ill update with engine trouble codes tomorrow also my tach will go to 0 rpm every once in a while, and my temp gauge is only ready 1/4 heat it should be in the middle of the gauge right i did replace thermostat but its unchanged the cooling system is under pressure tho and hot as hell when i grab he upper hose
i just noticed also that my radiator has 2 lines were the transmission lines would hook up but nothing is hooked in to them is this tranny supposed to be hooked into the transmission cooler its a 46rh tranny
I did buy a new speed sensor which came with new connector as i saw
the wires at the sensor were bare plastic insulation is gone ill change that
in the morning when i get home its a 3 wire
Here is a link to the autozone part that i bought
http://www.autozone.com/autozone/par...er=195855_0_0_
Trending Topics
