Problem really bad now
Old 01-12-2012, 04:34 PM
1stG92's Avatar
1stG92
1stG92 is offline
Default Problem really bad now
Spits and stutters like out of timing or running out of fuel.Over the past 3 weeks keeps getting worse.Working at night on this issue noticed the exhaust getting cherry red.By unplugging the vacuum to the fuel regulator on the fuel rail,it stopped.SO,I got another fuel rail and still does the same thing.Unhooked exhaust to make sure nothing was plugged and it was all good.I have also changed all 3 sensors on the throttle bottle body..Im really lost now.....Could this be something internal?
Old 01-12-2012, 10:47 PM
ditchdigger2012's Avatar
ditchdigger2012
ditchdigger2012 is offline
I had a problem that sounds similar to yours with my 95 SLT with the 318 mag. What it came down to was replacing the fuel pump. That fixed the "loss" of fuel pressure but even now it still turns over a lot before starting up.
Old 01-12-2012, 11:08 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
So did you replace the fuel rail or the fuel regulator?
Old 01-13-2012, 07:55 AM
1stG92's Avatar
1stG92
1stG92 is offline
I replaced the fuel rail as this piece I described before I took the vacuum off of was actually part of the rail.it is located on the back of the rail on the drivers side.I did a pressure test but came back good.Crazy,I remember you telling me the regulator was on the rail.If that was the regulator,It wasn't coming off.Still can't figure out why my exhaust gets so hot..
Old 01-13-2012, 02:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
When you tested the pressure did you do it with and without the vacuum line hooked up?
1993 Dodge Dakota Manual 31psi, 39 with no vacuum.
When you say you unplugged the vacuum line, did you plug up the vacuum hose?
The regulator is removable off of the fuel rail. Here are some pics that will help.
Old 01-13-2012, 05:10 PM
1stG92's Avatar
1stG92
1stG92 is offline
Thanx Crazy.VERY helpful yet my mechanic already changes the while rail.I'll inform him of this.Yes on the pressure test.Either way didn't make a difference came back good.For some reason there is way too much gas being pumped into the TB and turning my exhaust cherry red...Still sits and idles like a champ but stumbles when ya try to driver it.
Old 01-13-2012, 09:41 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Was the replacement rail used? If so you have a used regulator since it wasn't replaced. Who knows if that is any good.
If I remember right a LEAN condition is what produces extreme heat. You might be burning up your pistons and valves.
I can't remember if you ever said you replaced the O2 sensor.
Old 01-13-2012, 11:17 PM
93dakotaman's Avatar
93dakotaman
93dakotaman is offline
Your converter on the exhaust is pluged, check it.
Old 01-14-2012, 02:51 AM
1stG92's Avatar
1stG92
1stG92 is offline
Talked with my mechanic and he had unhooked the exhaust from the manifold still ran like **** so the cat wasn't the issue.Yes it was a used rail so I'm going to get a regulator (now i know how it comes off) and change it..Will give an update in the next few days as soon as I get it on..Ty all..
Old 01-14-2012, 11:38 AM
ministock6's Avatar
ministock6
ministock6 is offline
If the pressure is fine at idle, do a volume check, also I had one that had good pressure while idling, so taped the fuel pressure gauge to windshield and drove it and when driving down the road the pressure came down to 15 psi or so, you said when you unplug the regulator it ran good? Unplugging the regulator gives more fuel pressure, so by that statement your pump is bad
Quick Reply: Problem really bad now
