Dakota randomly dies out
Old Jan 18, 2012 | 05:04 PM
ombasketball03's Avatar
ombasketball03
Alright, Does the computer have to be programmed or what?
Old Jan 18, 2012 | 09:47 PM
silverpsycho38's Avatar
silverpsycho38
No programming necessary if you are replacing it with a factory on. I got my from the junkyard or you can go to yor local parts store and get a remanufactured unit.
Old Jan 19, 2012 | 05:33 PM
ombasketball03
I'm still considering my options in fixing this truck. Could the Throttle Position Sensor be a option? What exactly does this sensor do?
Old Jan 20, 2012 | 08:04 AM
silverpsycho38
The tps tells the computer how much fuel is needed from the injectors. If the tps was bad it would run poorly but not cause you to have no fuel pressure. I am guessing that you have the same problem I had and that was a bad computer. See if a local junkyard has a used one for sale.
Old Jan 25, 2012 | 06:19 PM
ombasketball03
I finally replaced the Computer today! Hopefully truck doesn't die out anymore. Thanks for the help guys!
