My Early Dakota
Old Sep 15, 2012 | 10:59 PM
Cdozier's Avatar
Cdozier
also ordered some 235/75's. I'll get some pictures once everything is done..Give me a week!
Old Sep 20, 2012 | 03:50 PM
bran1har's Avatar
bran1har
I know what the not starting right away problem is. Your check valve in your fuel pump unit is shot. It holds fuel pressure that way the truck will always start right up. Basically, whan you shut down the truck, that check valve is allowiing the fuel pressure to bleed off because it isn't sealing right, so when you go to start it up again, it has to rebuild that pressure. I had the same issue on a 96 v6. I got a reman pump assembly for like $28, a new one is about $170. You will need to get at the top of the gas tank so I would recommend removing the bed. instead of dropping the tank, its alot easier. Just 8 bolts.
Old Sep 21, 2012 | 09:28 AM
Cdozier's Avatar
Cdozier
Right on man I really appreciate you telling me that. I'll look into it.
Old Sep 21, 2012 | 09:29 AM
Cdozier's Avatar
Cdozier
Here ya go!! I have officially fell in love with this truck all over again...
DSC_0013 by dozierrrr, on Flickr
DSC_0014 by dozierrrr, on Flickr
DSC_0015 by dozierrrr, on Flickr
Old Apr 4, 2013 | 10:56 PM
Cdozier's Avatar
Cdozier
Hey fellas... Has anyone changed there rack and pinion bushings? Is it a pain or? Mine are looking pretty worn and I was thinking of doing it for preventative maintenance.
Thanks for everyone's time!!!
