1989 dakota TPS, O/D, and electrical issue ?
hello i have a 1989 dodge dakota with a suspected faulty tps sensor, i tested it the other day reading 1.50 ohms at normal position with the switch at run position. is that normal ? ive seen others at 2.50
also the truck has no 3-4 shift witch overdrive is 4th gear.
ive replaced the overdrive switch
all sensors are good besides the tps
wich brings up code 24** tps is out of range
here are the three codes that i pulled up
34* Speed control vacuum or vent circuit short or open condition detected OR speed control switch input outside accepted range
22** Engine coolant temp sensor signal outside the acceptable range
24** Throttle Position sensor signal outside acceptable range
overdrive fuse is good i checked it in the fuse box.
temp sensor was replaced, so i just have the tps sensor haunting me, and it wont go into overdrive
