CPU temperature sensor pigtail?
Old Jan 17, 2012 | 06:03 PM
89newbie's Avatar
89newbie
Default CPU temperature sensor pigtail?
Finally had climate to change CPU temp sensor. Pigtail is shot, wires going into it green with corrosion and when i tried to take it off the plastic crumbled in my fingers like maby it had been baked or something. I read the part is ot manufactured anymore( pigtail). Any Suggestions other than Junk yard? Any one have a good one out there that wants to sell it?
Old Jan 18, 2012 | 10:16 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Just get simple connectors from Radioshack or Walmart if wanted seal the connectors in RTV after you plug them in to keep it secure. Radioshack as well as several auto parts stores sells universal plugs, see if one will work, take your new sensor to try them out.
Used will be the next best choice, the sensor is the same on Rams, Dakotas, Vans, Durangos, Jeep GC.
Old Jan 18, 2012 | 09:46 PM
89newbie's Avatar
89newbie
LOL big guy you read my mind. THanks for the tips. Seems the shack here didnt have anything that would fit so I bought 3/16 slip ons and am fabing from that. Ill post if it works out.
Old Jan 19, 2012 | 08:58 AM
dobaroy's Avatar
dobaroy
Whats the CPU Temp Sensor? and where does it sit?
Old Jan 20, 2012 | 04:24 AM
89newbie's Avatar
89newbie
It gives the CPU a reading, different sensor than guage. If CPU doesn't see proper reading it causes hard starts in cold weather. It is located in the front of engine behind water inlet for the 318, very hard to see. I removed serpintine removed the four bolts that hold the A/C compressor for access. Temperature guage sensor is about the same area but toward the passenger side just a little, easy to see.
