Brighter backup lights
Old Feb 10, 2012 | 01:44 AM
  #21
WRXCarl's Avatar
WRXCarl
Originally Posted by WRXCarl
I've never checked into exactly how he wired them and seen if its all set up right but my friend has that exact set on his Dakota in the front and no joke if your sitting in the cab you can see better by only turning on the parking lights over just those. If this is true with all of them I'd say your current lights are brighter hahaha
although after reading the reviews they sound really good... will check his wiring job and get back to you on that
Old Feb 10, 2012 | 02:02 AM
  #22
HammerZ71's Avatar
HammerZ71
I made myself a little mount to slide into my hitch, have a dual wiring setup with a switch. Switch off and they are normal reverse lights, switch on and they stay on, so I can use them if I'm doing something behind the truck.
Old Feb 10, 2012 | 02:43 AM
  #23
Siwon's Avatar
Siwon
Nice, I'd rather have the switch inside the cab like maybe near the ashtray or something, or maybe make a cool box on the ceiling..
I'm going to Northern Industrial today when I wake up to look at the lights and a tool set they got. Hopefully they have the lights in stock.
The reviews basically say it's a beast of a light.
Old Feb 10, 2012 | 12:18 PM
  #24
Siwon's Avatar
Siwon
I bought the 2x set of them lights, 30 ft 18 gauge wire and an 18 gauge 10 amp switch.
Will with gauge work if the lights are 12v ~4.5amp 55watt?
According to this Wire Gauge Calculator, I would need a 20 gauge for the default 10% Allowable Cable Voltage Loss.
Here is what I typed in for 18 gauge:
Power Consumption 55w
Cable Distance 10ft
Allowable Cable Voltage Loss 5%
Source 12v
Calculated:
18 AWG
4.58 Amps
.07 Ohms allowable resistance
Old Feb 10, 2012 | 12:44 PM
  #25
HammerZ71's Avatar
HammerZ71
I do a lot of night fishing for big cats in south Georgia. We usually setup noodles or jugs and limb lines on the river from a jon boat and then fish from the sandbar with poles. I use the back of the truck and tailgate for gear and a bench for rigging/etc. So I found for my purposes it's more convenient to have my light switch at the tailgate.
Now I also built a fishing rig for the front receiver hitch on my Grand Cherokee that is lighted. I have a switch on it as well, but also used a wireless relay and setup an unused HomeLink (garage door opener) button to operate the lights as well as have a key fob for it. It's sweet...
Old Feb 10, 2012 | 10:41 PM
  #26
Crazy4x4RT's Avatar
Crazy4x4RT
I added in a rear adjustable light as well, with a switch on the inside.
Old Feb 11, 2012 | 07:56 AM
  #27
89newbie's Avatar
89newbie
LOL Crazy, After my mud experience on the back 40, really probly back .8, I immediatly thought thats a deal, can see when the truck is framed without getting down on your knee!
Old Feb 13, 2012 | 05:38 PM
  #28
Siwon's Avatar
Siwon
My New Lights/Bracket, they are straighter than it looks.. cell phone camera sucks and I was at an angle.
I mounted them to the towing chain holes.
Old Feb 19, 2012 | 02:09 AM
  #29
VINCE 91's Avatar
VINCE 91
I took the tractor lights off on Monday and put on lights like the post above.I used the holes in the bumper just above the hith, close to center. I wired them into the back up light wire on my 7 way trailer plug.
I never had a problem with clearance with the tractor lights except when backing up and not paying attention. I just switched them because I had them and it looks cleaner.
I bought them to put on the front, but couldn't decide where to put them.They ended up on the back.
Old Feb 10, 2013 | 04:04 PM
  #30
ms_sysghost's Avatar
ms_sysghost
Exclamation NO backup lamps!
I have a 1990 v6 3.9L SE that i've changed the bulbs, checked the fuses, and replaced the neutral safety switch on, all to no avail. Are there any other possible quandrys I might possibly look into? I hear they can come apart where the wiring splices together at the bumper as well.
