Dodge dakota 1996, fuel consumption.
Old 01-22-2012 | 04:16 PM
kallib's Avatar
kallib
Default Dodge dakota 1996, fuel consumption.
Hello,
i have a Dakota '96 with only 23k miles.
the engine is 3.9 magnum.
the fuel consumption is not like i expected.
i can do about 11-12 mpg.
if anyone has any ideas for me to fix this i would be very happy.
Thank you.
Old 01-22-2012 | 05:09 PM
g. man's Avatar
g. man
Check it for codes. There is a write up in the FAQ. My o2 sensor was causing my bad gas mileage.
By the way, I envy your location.
Old 01-22-2012 | 05:40 PM
VINCE 91's Avatar
VINCE 91
Check out this link for mpg ratings.I have it set for the '96 Dakota, but you can do them all.
http://www.fueleconomy.gov/feg/bymod...a_Pickup.shtml
I know this doesn't answer your question but it will give you something to shoot for.
Old 01-22-2012 | 10:40 PM
kallib's Avatar
kallib
thanks for the tip,
you should check my location more out, we got a lot of mopars which have been taken a step further, and a good nature
Old 01-22-2012 | 10:58 PM
89newbie's Avatar
89newbie
Originally Posted by kallib
Hello,
Thank you.
our 3.9 gets about the same in stop and go driving. Highway it gets between 24 and 25
Old 01-23-2012 | 09:53 AM
GreenDak22's Avatar
GreenDak22
New O2 sensor, spark plugs, air filter, clogged cat, and keep tires inflated...just to name a few common things to check/replace
Old 01-24-2012 | 08:12 AM
89newbie's Avatar
89newbie
Another thing that saves fuel is drive it like a big truck. Gonna do a post on that today under 1st gen.
Old 01-24-2012 | 10:00 AM
dobaroy's Avatar
dobaroy
Where is the 02 sensor located and is it just for pollution control?
Old 01-24-2012 | 10:55 AM
misfitdakota_95's Avatar
misfitdakota_95
on magnum engines (1992-1996) it's mounted in the tank with the fuel pump module assembly.
Old 01-24-2012 | 01:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The Oxygen Sensor is on the exhaust pipe just above the Cat.
I think you might be thinking of something else.
