Cab swap on my 91'
Old Mar 9, 2012 | 08:27 AM
  #21
dobaroy's Avatar
dobaroy
Do you mean that you plan to swap out the intake manifold to take the carb?
That would be neat to save the factory red paint for the Dodge symbol, will take awhile to mask that out.
Old Mar 9, 2012 | 09:44 AM
  #22
marcar1993's Avatar
marcar1993
Buy a vinyl decal. Lay it out, paint, then pull it up.
Old Mar 11, 2012 | 10:30 PM
  #23
shadowthedakota's Avatar
shadowthedakota
no its got 2 injectors in the throttle body so unless the mounting points are different it should b a direct swap.
i never thought about it...would be easier
sadly there is no app for the forum...we'll have to get on the mods about that...
had the truck running the other day. decided to reuse the old mounts since the top halfs were ok. drove it in and out of the garage.
Old Mar 25, 2012 | 07:11 PM
  #24
shadowthedakota
ok i know its been a long time but. i got the fenders on(still need to do some adjusting), all the body mounts are on and tightened down, windshield is getting installed tomorrow(friend is coming out to install it for me).
now the main problem is i had everything working then all of the sudden i lost all the lights.
its not limited to headlights, dash, brake ext...its everything. all the lights. brake ,tails, running lights, headlights, dome and dash lights. the only things that don't work on the truck. truck takes a couple of seconds to start(might be a dead battery) have a code 41 i believe but everything runs fine.
im thinking ground wire or fusible link
Old Mar 25, 2012 | 08:21 PM
  #25
shadowthedakota
Scratch that code it went away but I ran new ground wires all over the place and still nothing I jumped all the terminals in the switchcand the only one that worked was the headlights and also my turn signals are out
Old Mar 25, 2012 | 10:55 PM
  #26
Crazy4x4RT's Avatar
Crazy4x4RT
Some wire somewhere may have not got hooked up correctly or something shorted out and burnt up the main fuses or something. Good luck.
