2wd Auto to Solid axle 4x4 manual Questions
Old Mar 9, 2012 | 04:13 PM
hogback's Avatar
hogback
yeah i've looked at all the SAS stuff
What year ram should it be off of and I think ill fabricate the hangers and perches
whats a backing plate?
Old Mar 9, 2012 | 07:09 PM
hogback's Avatar
hogback
drivers side drop means the pumpkins on the drivers side right
Old Mar 9, 2012 | 10:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm not sure what years but www.napaonline.com has lots of details and pictures. Use 1/4 plate, you can get cheep ones pre-made from www.summitracing.com
Yes your correct.
Old Mar 10, 2012 | 08:01 AM
hogback's Avatar
hogback
do you mean the brake backing plate
Old Mar 10, 2012 | 09:34 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The top or bottom plate the leaf springs bolt to.
Old Mar 10, 2012 | 10:21 AM
hogback's Avatar
hogback
ok i know what your taking about now
what do you think is the cheapest way of converting to 4x4 solid axle
a junkyard
craigslist
or what
at my local-ish pick a part i can get a trans, transfer case, front axle, flywheel, leaf springs, clutch stuff, pedals, and driveshafts for around $600 do you think i can get this stuff for a better price somewhere else
plus i will need new gears and also maybe lockers
Old Mar 10, 2012 | 10:56 AM
hogback's Avatar
hogback
you know what might also be cool but i want opinions is that im thinking of making a awesome 2wd off road demon. beefy tires and a small lift manual trans and a locker. maybe a winch and bumpers. Is there any way i could get a 4wd trans and transfer case and only use it in 2wd until i put a axle in front
Old Mar 10, 2012 | 03:49 PM
hogback's Avatar
hogback
well this has nothing to do with this topic but today i took my bed off the truck and my truck is pretty rust free compared to others. Im now thinking of putting a flatbed on it. ill make it out of wood and make it look nice. The thing im wondering about is what is the best way to get rid of the bed. Scraping isnt going to be worth it. If I sell it how much should i sell it for it has alittle rust on the fender wells and barely any on the bottom of the bed. inside the bed is spotless.
Old Mar 10, 2012 | 05:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
for around $600 do you think i can get this stuff for a better price somewhere else plus i will need new gears and also maybe lockers
Cheapest way is to buy a truck with a solid axle. Most pre 90's they can be picked up cheep.
Next cheapest is to have a donor truck to pull everything off as you go.
Next is the junkyard, $600 sounds good.
Yes you can get the transmission and transfercase 4wd and drive shafts from a Dakota then it is an easy swap.
Cool! I've been wanting to do a flat bed if I kill the bed one of these days. There is a good write up in the FAQ2.
https://dodgeforum.com/forum/1st-gen...atbed-pix.html
https://dodgeforum.com/forum/1st-gen...e-finally.html
Old Mar 10, 2012 | 06:26 PM
hogback's Avatar
hogback
yeah it should be nice having a flat bed
im going to buy up all the parts i need for the swap then when i have it all ill convert it
