underdrive pulleys
underdrive pulleys
anyone install a set? have already completely eliminated a/c ( modified bracket) alternator pulley looks bigger than stock- would underdrive or overdrive it? i know on some kits they give u a option to overdrive the alternator to get charging amps back up if running aftermarket lights, hi power stereos etc.. current belt routing looks a little tight- may have to reroute it differently- belts looks too tight between alternator pulley and idler pulley next to it, thanks
No, however I agree, not a good choice. I have heard of many, some work, some dont. My only experience is on my friends mustang... It didn't work too well. Ran hot and didn't charge at idle/in town.
They give VERY minimal performance vs the possible down sides, and they are fairly expensive to find out you can't use them.
