95 dakota with dead miss ..
Old Mar 18, 2012 | 09:59 PM
bonestock302's Avatar
bonestock302
Default 95 dakota with dead miss ..
I have a 95 dakota with 5.2 . Upon leaving a friends house today , I started to speed up and noticed a dead miss , if you slow down it pretty much disappears , but if you push the gas all the way down , it will start pulling despite the miss but then it will mildly backfire a time or two ... , all plug wires are on and not burnt in two , no check engine light on or anything...
Ideas , suggestions ?
Old Mar 18, 2012 | 11:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Bad spark plug wires, bad spark plugs, bad distributor cap or rotor. Bad fuel injectors, bad wires, loose or worn conenctors. Low fuel pressure. Tons of possibilities.
Old Mar 19, 2012 | 05:17 AM
bonestock302
Odd thing is , if you put it in neautral and rev it up , there is no miss at all... I wonder if that means a new fuel pump...
Old Mar 20, 2012 | 03:06 PM
ngtyler1s's Avatar
ngtyler1s
Sounds like a spark issue to me
Old Mar 25, 2012 | 07:13 PM
shadowthedakota's Avatar
shadowthedakota
sounds like it needs a tune up. my 93 did that off and on till it got so bad that i couldn't drive past 25mph. did a tune up and it was back to normal.
