Spare Keys: Door vs Ignition
Old Apr 7, 2012 | 10:26 PM
pinkfloydeffect's Avatar
pinkfloydeffect
Question Spare Keys: Door vs Ignition
When I bought my 1988 Dakota off my grandfather I was given 4 keys minus the glove box. In other words two sets, both sets have one ignition key and one door key. I really wish I had one that fit both, did they even offer this option?
My buddie has a late 90s F150, when he bought it from a used sales lot it came with 4 keys as well. Only thing is three of his keys fit the ignition AND door and the fourth is a door only key (like if you needed someone to get something for you but not have access to moving the vehicle).
Any input on your Gen I keys? Can I have one made?
Old Apr 7, 2012 | 10:39 PM
weisel's Avatar
weisel
At least you have spare keys.....
Old Apr 7, 2012 | 10:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT
As for the early years I don't know if they came with 1 key but the newer years came with 1 key. My 89 TA came with 2 keys factory, the ignition key had the chip in it, 80's style security ignition.
Most large locksmiths can re-pin the locks to use a common key.
Old Apr 7, 2012 | 11:06 PM
pinkfloydeffect
Nothing fancy here, they can be made for $2 at TrueValue
I have a locksmith on my street that works out of his home I'll see if it's something he can take on, sounds like it's going to be expensive though...might be cheaper swapping ignitions if that is possible from a 92-96 (IF they came with a single key option)
Thanks!
Old Apr 7, 2012 | 11:13 PM
weisel's Avatar
weisel
I know...I'm planning on getting some key blanks with the Dodge logo, then get another set cut.
I have a '92, and it has separate keys for doors and ignition.
Old Apr 8, 2012 | 01:14 AM
93MissDakota's Avatar
93MissDakota
i only have one key for door and ignition
Old Apr 8, 2012 | 09:12 AM
JR318's Avatar
JR318
My 95 only has one key for door and ignition also. But the driver side lock cylinder is going to need replaced soon cause its hard to unlock the door. You have to kinda wiggle the key before it will turn. So if i buy a new door lock cylinder will it use a different key?
Old Apr 8, 2012 | 03:09 PM
pinkfloydeffect
Same problem here! My drives door key needed to be wiggled to unlock the door, I'm going to get the locks from both doors at a junkyard so they match then attempt to swap ignitions so all 3 use the same key.
Old Apr 8, 2012 | 06:35 PM
Motorcharge's Avatar
Motorcharge
My 90 is as base model as you can get and one key works everything.
Sounds like the OP wants a valet key, though they typically open only the drivers door and ignition.
Old Apr 8, 2012 | 06:54 PM
pinkfloydeffect
I think MINE is as base as it gets, 3 separate keys, crank windows, no AC, they even cheaped out on a TACH! It couldn't get any more inconvenient then maybe having two keys next to each other like bank vaults have haha.
