Hockey Puck Body Lift How-To
I had a body lift only on my bed for about a month before I got around to doing the cab. It looks funny and people will give the truck strange looks as they walk by, but technically you could just lift the bed. Cranking the torsion bars with stock keys will not make the front taller than the back unless the springs are sagging. If you like the look of the rear taller than the front, you can get blocks for between the axle and leaf spring, but don't use hockey pucks for that.
Picking up a 93 Dakota 2wd ext cab 3.9L v6 to beat the pies out of at the local mud spots in michigan, getting some good tires prolly 31s wanted to do the cheapest lift possible hockey puck lift came to mind, what bolts should i use grade 5 again cheapest but functional thanks guys
