1995 dodge dakota stalling
Old May 22, 2012 | 01:16 PM
beckman's Avatar
beckman
Default 1995 dodge dakota stalling
hi guys i have a 1995 dodge dakota and i replaced the IAC valve and it improved a little bit but the truck is still stalling when warm doesnt stall when cold just when engine is warm any help would be great thank you
Old May 22, 2012 | 02:18 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Since it only does it once it warms up, possibly a bad coolant temp sensor or O2 sensor.
Old May 24, 2012 | 12:09 PM
beckman's Avatar
beckman
there are no trouble codes wouldnt a cts sensor and o2 sensor set off a code just wondering
Old May 24, 2012 | 03:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Not all bad sensors set off codes. Only dead sensors sets off codes, but they don't have to be dead to be bad.
Old Aug 4, 2012 | 10:20 PM
John93poston@yahoo.com's Avatar
Default 1995 dakota 3.9 stalling
I have a 1995 3.9 auto dakota it stalls or my say loss of power checked fuel presser and volume test all ok checked sync its prefect new cap rotor pick up coil plugs wires new fuel pump clened injecters check map senor check for vacume leacks check timing chain no code new cat and muffler new egr valve iam lose any ideas when you hold gas at 1500 rpms the idea drops cleaned tb checked tps put it on a scan tool didnt find anything please help
Old Aug 17, 2012 | 12:40 AM
lblair04's Avatar
lblair04
Use punctuation and spell checker, so people can read what the hell you're trying to say.
Old Aug 21, 2012 | 09:05 AM
dana a's Avatar
dana a
New Member
Try the crank sensor its on pass side below the egr pipe two Allen head bolts.frst grab the wires and give them a pull.My 95 had the same problem replaced fuel pump cap roter ign coil ect. beat me up for a couple weeks but it runs great now hope that this helps.
