transmission
Old May 22, 2012 | 03:47 PM
chet.manly's Avatar
chet.manly
Default transmission
my trans went out in my 93 318 and i found a used trans out of a 94 ram 1500.
my question is this.
would it fit my truck?
Old May 22, 2012 | 04:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You didn't say what the Ram's engine is, if it is a V8 yes it will work. You also didn't say if yours or the Ram is 2wd 4wd, as long as it is the same it will work.
Old May 22, 2012 | 04:15 PM
chet.manly's Avatar
chet.manly
its the same engine and there both 2wd.
im just worried about the wiring
Old May 22, 2012 | 06:25 PM
siggie30's Avatar
siggie30
If memory serves correctly, you are replacing a 46rh, with a 46rh. The rh transmission has two- three prong wiring points, whereas the 46re has the 8 way plug just behind the selector on the driver's side. The only thing that may be different is the speedo gear inside the cable attachment.
Old May 22, 2012 | 08:25 PM
chet.manly's Avatar
chet.manly
-well I'll give it a try..I'm picking it up early tmw morning so I'll let you guys know how it went
thanks
Old May 26, 2012 | 09:40 PM
chet.manly's Avatar
chet.manly
the swap went well..but now my truck won't start in park..its gotta be in neutral..any ideas what it could be?
Old May 26, 2012 | 09:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The park neutral safety switch or the transmission rod needs adjustment.
Old May 26, 2012 | 10:11 PM
chet.manly's Avatar
chet.manly
I'll check that out in the morning..thanks!
