96 dak
Old Jun 3, 2012 | 07:16 AM
96dakbrian's Avatar
96dakbrian
Question 96 dak
I have a 96 Dakota throwing a52 code, could this happen because I hollowed out the cat. I did the anti foul trick
Old Jun 3, 2012 | 08:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It is possible you messed it up due to the hollowed out catalytic converter , since 96-up has 2 oxygen sensors. (1 before and 1 after the cat )
52** Fuel system rich
It could also be a leaky fuel injector or a bad fuel pressure regulator or weak spark.
Since it is a 96 it is OBDII so you do have the OBDII connector which when using a scanner or a code reader it can give you more detailed trouble code.
Old Jun 4, 2012 | 06:41 AM
96dakbrian's Avatar
96dakbrian
thank you for your time
