Lift question
Old Jun 16, 2012 | 08:58 PM
Volkster13's Avatar
Volkster13
Default Lift question
This is probably a stupid question ....
So I'm thinking of giving the Dakota a lift I was going to add a leaf I was wondering if there was something you could add to the front also to lift it a little? My dad was saying maybe adding springs from a v8 would lift it some??
Old Jun 16, 2012 | 11:38 PM
Crazy4x4RT's Avatar
Crazy4x4RT
For a 4wd you can crank your stock torsion bar keys to get 1-2in. Or buy indexed keys for 2-3in. All the lifting info you ever need is in the FAQ2 along with how to crank up your keys and where to buy the indexed keys.
Old Jun 17, 2012 | 07:46 AM
Volkster13's Avatar
Volkster13
Ohh okay thanks!
Old Jun 17, 2012 | 11:23 AM
buick's Avatar
buick
Also, I'd say the indexed keys give you 2" max. Mine can go another inch tighter, but the bars start to bend, which I'd think is quite dangerous.
Old Jun 26, 2012 | 09:08 AM
Volkster13's Avatar
Volkster13
I got the rough country add a leaf yesterday is there a step by step how to somewhere that explains it better than the confusing instructions they give you
Old Jun 26, 2012 | 04:46 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It's very simple.
Lift the truck where the suspension is unloaded.
Unbolt the U-bolts.
Drop the axle enough to clear the springs.
Place C-Clamps on the leaf pack.
Unbolt the center pin.
Remove the C-Clamp
Install the leaf at the bottom or above any leafs that are smaller.
Re-install the C-Clamp and the center pin.
Then put everything back together.
The brake lines and cables and wires and shocks and driveshaft may or may not have to be removed depending on how much room you have to lower the axle to get to the leaf springs.
Old Jun 26, 2012 | 08:58 PM
Volkster13's Avatar
Volkster13
Thanks!!
Old Jun 28, 2012 | 04:32 PM
Juvenator93's Avatar
Juvenator93
Default New kid on the block
hey guys, its my first time on here. i would always look here for help and decided to join. I'm getting a torsion key leveling kit on my truck. I'm Currently running 30x9.5 on the stock rims but want to go 32x11.5 on some cragar soft 8s. i should be able to clear them right? the website says i can fit 33s but i want some opinions from you guys.
Old Jun 28, 2012 | 05:01 PM
Volkster13's Avatar
Volkster13
Well tried to install them today and looks like I'm Gunna need some pb blaster to get the u bolts off they won't budge at all
Old Jul 11, 2012 | 04:55 PM
Volkster13's Avatar
Volkster13
Currently installing the leafs
Edit... We broke a brake line..
And looks like we won't be able to install them(at home at least). the pin that goes down the center of the leaves was welded onto the stock leaf by someone.
