94 Dakota Tensioner Pulley Issue
Old Jul 10, 2012 | 10:29 PM
DanAustin1's Avatar
DanAustin1
Default 94 Dakota Tensioner Pulley Issue
I recently bought a 94 Dakota Extended cab, 3.9 v6 from the original owner to give to my little bro when he turns 16. I was doing the full tune up and the bearings are bad on the tensioner pulley, The factory pulley is a little over 90mm everything I can find online is 76mm Auto zone and oreillys only carry the 76mm, If I use the belt for the truck (new one) it doesnt get tight with the smaller pulley, So...Should I buy another belt (shorter) and run the smaller pulley or does anyone know where I can find the right pulley for the truck. Its got power steering, Ac and how do i find out if the AC is factory or dealer installed? That was a question that kept coming up at auto part stores. Thanks! Heres some pics, Super super clean, Power windows mirrors Ice cold AC everything works the way it should. I took the camper shell off as soon as I got the truck home.
Putting new battery so didnt have to push off trailer
Old Jul 10, 2012 | 10:32 PM
DanAustin1's Avatar
DanAustin1
Sprayed the bed rails with bed liner to cover the scratches from the dealer installed shell that had been on there since the truck was new.
The shell gave it away on CL
Old Jul 11, 2012 | 12:45 AM
93MissDakota's Avatar
93MissDakota
really nice dak you got there, looks like shes in good shape still
Old Jul 11, 2012 | 05:31 AM
JR318's Avatar
JR318
I replaced all the pulleys on my 95 and just bought what autozone had and it all worked out. The pulleys were all the same size so im wondering if it has been replaced before without the proper pulley. I would suggest use the pulley everybody has and use a shorter belt that way if you get stranded somewhere because of either the pulley or belt then you can just get the part pretty much anywhere. Thats a good looking truck and your brother will really enjoy it.
Old Jul 11, 2012 | 07:03 AM
DanAustin1's Avatar
DanAustin1
Thanks I only paid 100 for it . All service records , all receipts for anything that has been fixed or replaced. Ive know the guy for a couple years now he bought a new truck last year and this has just been sitting in the garage wife told him it had to go. Has brand new tires only one tiny dent in the door. All original parts have been used to keep it in shape. I got it home Sat did the battery and oil change and put a 100 miles on it cruising around to make sure it was gonna run good before I started doing the tune up. Theres no rust , and not a single thing doesnt work I was surprised when I cranked the ac and it blew ice cold.
Old Jul 11, 2012 | 10:42 AM
Crazy4x4RT's Avatar
Crazy4x4RT
For the correct pulley I would try Napa or your local Dodge dealer. Also there are 2 versions of the belts listed for our motors one is slightly shorter than the other you can get the specs from the autoparts store.
The AC looks factory from the picture. If you want to know for sure you can request a build sheet from Dodge that showed everything that came stock on the truck. The link is in the FAQ in this section.
Old Jul 11, 2012 | 01:12 PM
DanAustin1's Avatar
DanAustin1
Sweet thanks. Yeah gonna try the dealer first today then will go with the smaller pulley and shorter belt.
Old Jul 11, 2012 | 09:52 PM
93MissDakota
100 bucks?!?! are you serious damn....
Old Jul 11, 2012 | 10:51 PM
DanAustin1's Avatar
DanAustin1
Yep the guy let it sit for the last year and half in the garage. All wrapped up wife said time to get rid of it they are pcs'ing (changing duty stations) and she didnt want to take it. Ive been offered $2500 for it already. Heres what I have in to it
$100 Truck
$8 fuel cap had to snap the locking one off
$10 Air Filter
$98 Plugs , wires, cap, rotor, PCV valve
$26 oil change
$2 Spare key
$55 Serpentine belt/Tensioner pulley
$104 battery
$40 gas
Old Jul 11, 2012 | 10:54 PM
DanAustin1's Avatar
DanAustin1
Finally got the pully and belt done! no more bad bearing After the tune up runs like a champ. I thought it had an exhaust leak but one of the manifold bolts had just came loose tightened it up and no more leak wasnt looking forward to changing the exhaust manifold gaskets. And gotta be one of the easiest spark plug changes Ive done to date.
