Stalling issue !!!
Old Jul 17, 2012 | 07:00 PM
adrenalinejunki's Avatar
adrenalinejunki
Exclamation Stalling issue !!!
Ok i need some help here, i just picked up a 92 Dakota ext cab 4x4 5.2 and it needs some help and i have been starting to wrench on it. When i start the truck it idle perfect no hesitation.. when i shift into drive or reverse and TAP the gas the idle falls on its face and the truck dies. I have a new TPS, IAC, Fresh gas, Cleaned Carb and Coolant Temp Sensor.. I am losing my mind with this at the moment so any help would be greatly appreciated !!!
Thanks Again !
Old Jul 17, 2012 | 10:32 PM
93MissDakota's Avatar
93MissDakota
which coolant sensor? the one for pcm right, and theres that idle air control valve thing on the back of the throttle body thats known to stick
Old Jul 18, 2012 | 05:39 AM
JR318's Avatar
JR318
Its not uncommon to get a bad sensor right out of box if you bought it from anywhere but the dealer. Make sure he new sensors are good and also like 93missdakota said there are some times 2 coolant temp sensors and the one to the left with one wire is the one for the pcm. The other is for the gauge and will not affect how the engine runs.
Old Jul 18, 2012 | 12:52 PM
adrenalinejunki
New fuel filter, iac adjusted back in and reinstalled, all new plugs and fuel systrm cleaner in the gas and there is still a low rpm hesitation.
Old Jul 18, 2012 | 02:02 PM
adrenalinejunki
Truck stalls out when in reverse and you press and release gas pedal.
Old Jul 18, 2012 | 04:44 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Tons of possibilities low fuel pressure/volume via bad pump or dirty filter or clogged injectors ect. Vacuum leak which would include a bad EGR valve. A bad MAP sensor. Weak spark from coil or plugs or wire or cap and rotor. Bad IAC tons new out of the box are bad.
Old Jul 18, 2012 | 04:56 PM
adrenalinejunki
if i unplug the new TPS sensor it runs like a champ, check enging comes up.
Old Jul 18, 2012 | 06:06 PM
adrenalinejunki
Problem solved, Bad EGR valve even after i cleaned the original one. Now my question is can i bypass it or shoud i replace it
Old Jul 19, 2012 | 02:07 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Replace it.
