Injector swap/questions
Old Aug 14, 2012 | 01:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Without the need for a higher fuel pressure your not going to do anything but richen it up and may make it worse with poor MPG.
What engine did it have and what does it have now?
But if you have a need for higher fuel pressure like a larger engine then stock or forced induction, on 92-93 it is as simple as swapping your fuel pressure regulator for a 96 Dodge Intrepid which IIRC runs at 50-60psi?, stock 93 V6/V8 run 31-39psi?.
The other option is to install an universal fuel pressure regulator. Which for those with 94-up may be your best bet other than swapping out fuel sending units.
Old Aug 14, 2012 | 10:17 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Originally Posted by nemesis158
Swapping the injectors hasn't seemed to affect anything so far. id like to try increasing my fuel pressure, how is this done?
If you have a '92 or '93 you can do what I did once I converted my '94 returnless system to a '92-'93 return system: https://dodgeforum.com/forum/1st-gen...-360-swap.html
Read down far enough and I explain how to build an adjustable fuel pressure regulator with stock parts.
A.J.
