front driveshaft removal
Old Jul 21, 2012 | 12:20 PM
95slt's Avatar
95slt
Default front driveshaft removal
trying to get more clearance so my y pipe will fit- disconnected the front axle end but am having difficulty at the t case end. Tried vise grips but don't have the grip strength to make tight enough so won't spin.. Tried 5/16 7 mm 8 mm etc they are either too big are too small. Any help would be appreciated, thanks
Old Jul 21, 2012 | 12:52 PM
Hahns5.2's Avatar
Hahns5.2
Pretty sure the bolts are 5/16.. Try heating the yoke around the bolts with a propane torch for a bit, but be careful not to melt the output seal.
Old Jul 21, 2012 | 01:17 PM
95slt's Avatar
95slt
thats my problem...can't find a wrench size that fits..5/16 too big 7mm too small etc.. tried I bolt remover kit I have, same crap. almost to the point of saying the hell with it and grinding the bolt heads off and pulling it that way
Old Jul 21, 2012 | 09:16 PM
shadowthedakota's Avatar
shadowthedakota
the rust on the bolt probably shrank the end of the bolt down. if it gets bad enough just take the 7mm and hammer it on. it should come out then replace the bolts(they have a kit at the autostores for it
Old Jul 22, 2012 | 12:06 AM
mazda7475's Avatar
mazda7475
i understand what your going through. i used a lot of lube, heat and a pair of vice grips. it took an entire day to get 4 bolts out without breaking them.
i replaced the them with grade 8 bolts that take a hex key, then i ran into a second problem. stock hex keys will not go into the bolt because of clearang issues. i cut half of the end of the key and it worked great.
Old Jul 22, 2012 | 01:37 PM
95slt's Avatar
95slt
a ratchet won't fit.. got one out using 6 point 5/16 1/4 drive socket with mini breaker bar to crack lose and then finish with a wrench, but broke the breaker bar..went to lowes/ sears to get new tools..a couple options now..even discovered that side terminal battery remover wrench are 5/16 6 point! hope got this resolved soon..the dakota isn't my only project
Old Jul 22, 2012 | 08:28 PM
JR318's Avatar
JR318
The bolts are old and worn out. Cut them off and replace with new
Old Jul 23, 2012 | 10:34 AM
95slt's Avatar
95slt
got them out in 2 seconds with craftsman go thru socket set.. definitely a tool set that earned its keep to me now! but I think the front u joint is shot..grease barfed all over it...hard to change? never did one.. my friends always used a vise to do one
Old Jul 24, 2012 | 05:22 AM
JR318's Avatar
JR318
It can be done without a press or vice its just a real pita
Old Jul 24, 2012 | 07:28 AM
95slt's Avatar
95slt
my friend thinks its fine, just someone overgreased it...didn't clunk or anything
