if your having slipping issues check here --->
Old Aug 3, 2012 | 01:12 PM
v6dakota95's Avatar
v6dakota95
Exclamation if your having slipping issues check here --->
okay, just my .02 here. but after long long thoughts i finally decided to take my truck into my local transmission shop to get the fluid and filter changed and told them about the slipping from 1st to 2nd gear (automatic) even when the fluid is full. well once they drained everything the fluid was pretty rough looking and the filter was filthy lol, anyways.. they checked the bands and they were really out of wack which was why it was doing that, after they torqued them and put the filter and pan back on they put some of the high quality detergent then added 6 quarts of fluid and ive been driving it a few hours and it shifts real nice and doesnt slip anymore either.. just my 2 cents in case your having the same problem.
Old Aug 4, 2012 | 02:16 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool, I'm glad it was an easy fix for you.
Old Aug 4, 2012 | 07:39 PM
wyrmrider's Avatar
wyrmrider
My concern is double
first what is this "high quality detergent"
second
did they fill with ATF+ 4?
With ATF+4 you should not need any additives
Without ATF+4 additives may cost you your converter> plug up your trans cooler>destroy your thrust washers> destroy your trans
dexron (Amsoil etc) plus additives does not equal ATF+4
Old Aug 5, 2012 | 04:12 PM
v6dakota95's Avatar
v6dakota95
im panicing while im driving it lately, it feels alot different then it has before, i know the fluid they put in and stuff looked a lil thicker and it shifts better.. but like every sound i hear i think its going out because i read all over forums hearing doing a fluid filter band adjustment on that many miles can help or make it worse.. all the transmission shops too say just give it a little bit and youll forget about it. the slip from 1st to 2nd occurs sometimes still but i dont think theres much i can do about it now..
Old Aug 5, 2012 | 09:57 PM
wyrmrider's Avatar
wyrmrider
Answer the question
what did they put in your trans
ATF+4 or snake oil?
Do you have a 518=46 RH or electronic?
If electronic consider a flash
do not worry about folk wisdom on the forums
Fresh fluid in a Dodge trans never hurt one that one not gone already
First second is a combination of overrunning clutch (sprag) and clutches apply
(low/ reverse band release > clutch if manual low
Put in a transgo reprogramming kit
flare up can be as simple as a linkage adjustment- adjust it out just a little and see
does your trans seem to shift "early" or "late"?
I think there is a diagnosis sticky- find and read
Old Aug 5, 2012 | 10:34 PM
v6dakota95's Avatar
v6dakota95
well heres the thing i checked my tranny fluid earlier and it was almost 2 QUARTS LOW!! they didnt even fill it all the way.. im going back tomorrow raising hell and asking for a refund or something cuz this is bs. shifts just fine and doesnt slip anymore either thank god
Old Aug 6, 2012 | 08:52 AM
MoparMan1991's Avatar
MoparMan1991
I'm just dying to know why you need three current threads on the same thing.
Do tell.
Old Aug 6, 2012 | 11:45 AM
wyrmrider's Avatar
wyrmrider
low fluid would do it
but If you checked cold it would show low
did you check it HOT?
and what fluid did they put in?
what snake oil?
