misfire help please
Old Aug 9, 2012 | 01:40 PM
superfast_318's Avatar
superfast_318
Default misfire help please
hi guys im new here i have a question i have a 1995 dodge dakota extended cab 2 wheel drive 5.2L v8 it has 150,000 miles im have a misfire issue here it is...ok between 1800 rpm -2200 rpm at steady throttle i have a bad missfire.so far ive done this to try to correct it..quality full tune up,crank position senser,coil,throttle body gasket,fuel pump was replaced recently the plate in the distributor was replaced,injectors replaced, ignition switch replaced.map senser,tps senser,idle air control valve senser. i did check the fuel pressor its at 40psi and also drove the truck with the fuel pressure gadge on and when it was missfireing the gadge stade normal this problem has got me puzzled please help me what are your thoughts?....
Old Aug 9, 2012 | 02:15 PM
superfast_318
Default forgot to mention
running through all gears gas peddle floored (did that for testing purposes to see if it misfires that way) and it didnt at all...
Old Aug 9, 2012 | 07:03 PM
volaredon's Avatar
volaredon
40# pressure on a 95 is about 10# LOW
Old Aug 10, 2012 | 09:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Actually according to the 95 Dodge Dakota Factory Service Manual 40 just right.
1995 Dodge Dakota Manual (35-45 psi) at idle.
The best way to start is to find the miss. Start by unplugging each injector (while the engine is running and it is missing) 1 at a time and listen and feel for a change in the engine. The 1 injector that doesn't change the engine is most likely your problem cylinder. Check the injector swap it around, check the power check the spark plug swap that around check the spark plug wire. ECT.
Old Aug 11, 2012 | 08:51 AM
volaredon's Avatar
volaredon
1995 Dodge Dakota Manual (35-45 psi) at idle..
Really? From what I remember that was pressure for 92/93 with 2 line (feed/return) fuel system and the 94+ with single line returnless was like 49-50
Old Aug 11, 2012 | 12:21 PM
Crazy4x4RT's Avatar
Crazy4x4RT
92-93 had even less. Your thinking of 96-up no-return is 49.2 ± 5 psi
1993 Dodge Dakota Manual 31psi, 39 with no vacuum.
1996 Dodge Dakota Manual (49.2 psi ± 5 psi) at idle.
I put together list of fuel pressures of years Dakota and Ram per service manual. Also added in a list of fuel injector specs. Its in the FAQ if anyone ever needs it.
https://dodgeforum.com/forum/2592323-post4.html
Old Aug 15, 2012 | 02:33 PM
superfast_318
does nobody know anything about this on this forum 186 views and nothing
Old Aug 15, 2012 | 04:49 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Did YOU do what I suggested so YOU can find the miss? ONLY YOU CAN FIND IT. We all gave you tools to figure it out. YOU have to figure it out.
Like I said YOU will have to find the miss then YOU can fix it.
Old Aug 16, 2012 | 11:46 AM
superfast_318
mine misfire only happens when driving steady @ 2000 rpm not at idle
