Tailight houseing screws
Old Aug 20, 2012 | 09:57 AM
Hansm14's Avatar
Hansm14
Default Tailight houseing screws
My screws keep loosening on rough roads and fall out .I keep tightening them and forget to tighten them.Can't overtighten the screws or you'll break the houseing.Just plastic. What can I use to hold the screws in place and be able to remove the lens if I ever have to,like for replaceing the bulbs? Annoying problem to be driving and see the houseing dangleing from the back.Duct tape would'nt look cool. 94 Dakota. Thanks
Old Aug 20, 2012 | 10:43 AM
Crazy4x4RT's Avatar
Crazy4x4RT
There are small metal clips that the screws thread in to. They are replaceable, or sometimes you can get away with using some pliers to try straighten it out to hold the screw better.
Old Aug 20, 2012 | 01:23 PM
Hansm14's Avatar
Hansm14
I replaced those also,and tried bending them tighter.No luck.
Old Aug 20, 2012 | 07:25 PM
Hansm14's Avatar
Hansm14
Would a threadlocking adhesive ,like Locktite work? Supposedly once you use it,you can remove it also,by hand tools.
Old Aug 20, 2012 | 11:12 PM
VINCE 91's Avatar
VINCE 91
If you use locktite, use the blue locktite, not the red.
Old Aug 20, 2012 | 11:15 PM
VINCE 91's Avatar
VINCE 91
I dont know why the screws keep coming out. Thats wierd. But you can put them in and also put a little clear nail polish on the heads and lense.
Old Aug 21, 2012 | 09:29 AM
Hansm14's Avatar
Hansm14
Thanks.They keep loosening only on rough gravel roads and rocky roads.Have done this for several years now,but I forget to tighten them when I get off the rough roads.Even went to different screws.Want to be able to remove the lens too,in case I have to replace a bulb.
Old Aug 21, 2012 | 01:16 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A simple trick is to use a piece of paper clip into the metal clip. This way the threads of the screw have something to bite into.
Old Aug 22, 2012 | 11:45 AM
Hansm14's Avatar
Hansm14
I ended up using blue locktite.We'll see what happens.I don't go on rough roads that often anymore.
Last edited by Hansm14; Aug 24, 2012 at 09:51 AM. Reason: Left out one letter,mispelled word
