Can I add atf to dexron?
Old Aug 26, 2012 | 10:15 PM
wyrmrider's Avatar
wyrmrider
NO RTV period
if you have a gouge use anarobic gacket maker , permatex makes one
anarobic means it cures without air
using rtv and no gasket is asking for a breakdown
using rtv with or without a gasket gets crap in your tranny
I see that there are "special" rtv's for oil and tranny fluid
I have not tested
any guinnea pigs out there?
If you want to use a dressing on your gasket use Hylomar
Old Aug 27, 2012 | 09:58 AM
ZacoWacko's Avatar
ZacoWacko
I found the leak. It was the dipstick. I pulled it and it is cracked where the seal is. Looks like whoever pulled the transmission didn't take the tube out and cracked it. Parts store doesn't carry them. I guess i will be calling the salvage yard to see if i can find one.
Anybody have an extra one from a teardown or something.
Old Aug 27, 2012 | 10:34 AM
wyrmrider's Avatar
wyrmrider
any tranny rebuilder or tranny rebuilder warehouse should have one
or
It's a standard o ring
just match it up at NAPA or another good parts store
Old Aug 27, 2012 | 12:41 PM
ZacoWacko's Avatar
ZacoWacko
I think i got the right o ring, but the tube is cracked at the ring
Old Aug 28, 2012 | 10:01 AM
wyrmrider's Avatar
wyrmrider
get a tube from a magnum
some like vans are longer
big blocks are different
so get the right one
