Stripped out caliper bolt hole...help!
Old Aug 31, 2012 | 12:44 PM
bwdakrt's Avatar
bwdakrt
Originally Posted by eli346
That's what I've been trying it just doesn't want to go so I'm wondering if maybe the threads or something are messed up on the end of the bolt even though they look fine. Ive wondered a few times if it's even the right bolt because it seems huge for the hole and the bolt head sticks out an inch or more farther than in needs to in the back and the spacer thing doesn't even fit through the rubber piece so it doesn't seem right
Unless it was packaged wrong the oversized bolt will work.
I do not mean for this to be offense in any way or to belittle your mechanical abilities but I have to ask...you are turning it the right direction, correct? Righty tighty lefty loosey?
Old Aug 31, 2012 | 12:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The overside caliper bolt work great for me. Take your time use WD-40 and back off ever step or so to keep the bolt from over working while cutting the new threads.
Old Aug 31, 2012 | 02:14 PM
eli346's Avatar
eli346
Did it start cutting in right away for you?
I already double checked that because it was the only reason i could think of that was making it not go in
Old Aug 31, 2012 | 02:32 PM
jc2168021680's Avatar
jc2168021680
You'd be amazed how easy this would be if you rethread the hole with a tap that is the same size as the new bolt. It might even work to rethread it to the original size if the hole isn't bored out too bad.
Old Aug 31, 2012 | 04:41 PM
eli346's Avatar
eli346
Just got home from Napa turns out I was right they gave me the wrong one so I'm going out to fix it now.
Old Aug 31, 2012 | 09:38 PM
eli346's Avatar
eli346
Well it was to far gone for the oversize bolt....I hate this truck more everytime I have to work on it.
So I'm thinking it could be drilled and tapped to m10 x 1.25? the problem is finding a bolt for it
Old Sep 1, 2012 | 10:17 AM
Hahns5.2's Avatar
Hahns5.2
They sell a specific heli coil kit for this...
Old Sep 1, 2012 | 10:51 AM
eli346's Avatar
eli346
Just seems a lot easier to tap it and use a bolt. It'll be stronger and save me $35 over the heli coil kit.
Old Sep 1, 2012 | 11:58 AM
bwdakrt's Avatar
bwdakrt
https://dodgeforum.com/forum/2857893-post7.html
Old Sep 1, 2012 | 12:39 PM
eli346's Avatar
eli346
http://www.boltdepot.com/Metric_sock...ted_steel.aspx
This ones close I can't find the actual one again at the moment though
