Truck running lean??
Old Oct 4, 2012 | 11:30 AM
adrenalinejunki's Avatar
adrenalinejunki
Default Truck running lean??
pulled a plug on my truck and it was white... i believe its running lean so i need to figure out how to get more fuel?? without breakin the bank
Posted from Dodgeforum.com App for Android
Old Oct 4, 2012 | 09:13 PM
Arcaporale's Avatar
Arcaporale
Maybe it needs less air, not more fuel. Looking for vacuum leak seems like a good place to start.
If your good in that department, rent or buy a fuel pressure gauge and have a look at your fuel pressure.
Giving your throttle body a cleaning may not be a bad idea.
You can also get a stethoscope or jerry-rig some device and check your fuel injectors for proper operation.
I would also look at sensors like MAP, TPS, O2, and temp sensors. Get a multi-meter if you don't have one already and look up how to test them. Not all sensors throw a code when they go bad.
