Dodge Dakota's 318 carb leaking from everywhere
Old Oct 11, 2012 | 01:17 PM
One to Remember's Avatar
One to Remember
Default Dodge Dakota's 318 carb leaking from everywhere
I have a 1988 dakota, i have a 318 in it with a carb from a 1974 dodge charger carter bbd 2 barrel. i have bought a new gasket kit for it. the new gaskets leak, gas rises all the way from the space behind the cup opening at the top, its only held by one screw anyway, im using the fuel pump from an '89 dakota with the 6 cyl, im just wondering why this thing is hemorraghing gas and what i can do to fix it. ive replaced all the internals with the kit stuff it leaking before and after the rebuild.
Old Oct 11, 2012 | 07:27 PM
volaredon's Avatar
volaredon
bad float?
Old Oct 12, 2012 | 11:26 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 1st generation Dakota sub-forum.
Old Oct 12, 2012 | 11:44 AM
keilkravec's Avatar
keilkravec
probably too much fuel pressure. carbs only need I think 4-8 psi. injection systems run on more than double that.
Old Oct 13, 2012 | 04:20 PM
One to Remember
this is what im going to get:
http://www.ebay.com/itm/UNIVERSAL-AL...&forceRpt=true
says it has 1-15 psi, then 140 psi, i got the 318 but maybe its v6 was fuel injected so i think the reg will help me out. i appreciate everyones input. if anyone else wants to weigh in i'd be gracious as well.
Old Oct 14, 2012 | 12:05 AM
keilkravec's Avatar
keilkravec
Yea the 88' was an injected motor, toilet bowl type but still injected. If it's kicking up 140psi I'm a bit suprised it has blown the lines off the carb yet O_o
Old Oct 14, 2012 | 12:10 AM
siggie30's Avatar
siggie30
Definately too much pressure. I reused my pump from the 89' when I went carb, but I put a regulator on it.
Old Oct 19, 2012 | 07:38 PM
One to Remember
well it sez it will go up to 140 psi but alot of these ads on ebay or vague at times.. im still waitin for it to get here. amyone got any idea how much cranking amps this truck takes too? im dying alot right now because i can only get like 5 cranks and the fuel issue is the reason for the excess cranking
Old Oct 20, 2012 | 10:51 AM
siggie30's Avatar
siggie30
POI, double the C.I. of the engine for amperage of battery. Ie, 239x2 = 478 CCA minimum. Your battery may have a bad cell if you are only getting 5 cranks out of it.
Old Oct 20, 2012 | 08:25 PM
One to Remember
siggie what psi did u settle on for ur carb and is your pump connected by new wiring or did u utilize the old wires, which should be white for pos and green for neg? im trying to utilize the old wires so i wont hAVE to use this light switch but idk if they work still or what.
