transmission slippage
Old Oct 23, 2012 | 10:31 AM
ditchdigger2012's Avatar
ditchdigger2012
Default transmission slippage
Without making a long story I had just pulled out of a driveway onto the roadway with the transmission working fine. Then I noticed it was running higher rpms than usual so I let off the gas and when I came back on it (gently) it acted like it was in neutral. Pulled over and noticed fluid leaking from front of trans so I added quart of fluid and tried again. Had to rev it in neutral a couple times before it would engage when in drive. Did the same thing again after a stop sign just around the corner and I barely got it to move again to make it the last half mile to destination. I let it sit for 1hr 15min and when I tried it the tranny engages just like it always has and doesn't feel like it slips. What is the problem? Any help will be greatly appreciated
Old Oct 23, 2012 | 12:34 PM
1stG92's Avatar
1stG92
With mine it was the throttle body in the tranny that needed to be rebuilt but I decided to go with a complete rebuilt to save hassel of something else going wrong down the road and having to pull it again..
Old Oct 23, 2012 | 12:46 PM
kahanabob's Avatar
kahanabob
i would sort out the fluid leaking from the front you described. when you added fluid it has to get cycled into the converter, maybe thats why it took a while to work right?. might be time for a fluid flush and filter change, thats after the leak issue is solved.
Old Oct 23, 2012 | 01:46 PM
ditchdigger2012
Okay thanks for the input..ill see what I find
