87-96 Chassis Build
Old Nov 30, 2012 | 11:41 PM
pinkfloydeffect's Avatar
pinkfloydeffect
Default 87-96 Chassis Build
I'm going to bite the bullet and build a new chassis and drop my body on it so I can continue to drive mine, my 88 body would deff fit on a 95/96 frame with no problem right same exactly body mounts etc? This way I can also get setup with the LSD axle I want, NV3500 and the 5.9L Magnum...I can Por15 everything this way too.
Something I would really like to do if I am going to do this though is convert to 4x4 but did they even make a reg cab 4x4 with a short bed? Even if they did it sounds extremely hard to locate a frame for...I think I would be better off making a RWD frame 4x4 or shortening a 4x4 frame (probably shortening since the front suspension would already be setup?)
Old Dec 9, 2012 | 06:25 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like a good plan.
For a 4wd swap check my 4wd in my sig.
I would assume they did make single cab/short bed 4wd Dakotas. Anyone have one that wants to post up?
Old Dec 9, 2012 | 08:42 PM
pinkfloydeffect
On another forum I heard they do exist, and even in a 5-speed 318 config. They said it would be easier to convert a RWD frame to 4x4 than to shorten one.
Old Dec 10, 2012 | 01:18 AM
marcar1993's Avatar
marcar1993
I've got a standard cab, short bed 4wd. Yes, they do exist, and dont seem any harder to find than any other 1st gen dakota in my area.
Old Dec 10, 2012 | 08:55 PM
shadowthedakota's Avatar
shadowthedakota
in my area they are scarce. i know of one guy remotley close to me who has a buch of sc/sb 4x4 frames and he was an arm and a leg and maybe even a first born for them.
Old Dec 10, 2012 | 09:16 PM
pinkfloydeffect
Screw it I will convert a frame over to 4x4 then, but if I get a 9.25 / 3.9:1 rear axle does the front have to be 3.9:1 ??
Old Dec 11, 2012 | 01:57 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes correct, both have to match.
Old Dec 11, 2012 | 10:10 AM
pinkfloydeffect
So in that sense...when I look for my axle find a 4x4 because the front will already be the same from the factory as the rear? Gotcha
