tranny problem
Old Dec 12, 2012 | 11:41 AM
4x4troy's Avatar
4x4troy
Default tranny problem
I have a 93 dak 5.2 4x4 with an auto tranny. the tranny is broke....no surprise...lol, I also have a 94 ram 1500 5.2 2wd tranny. if I swap the od unit and tcase over will it work in my truck?i want to convert the 2wd tranny to a 4x4 one. I found a link that showed how to do a 42rh...would the 46rh be the same? both of my trannys are 46rh's.
Old Dec 12, 2012 | 01:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
According to what others said yes just swapping out the OD units will work to convert it.
volaredon's Avatar
volaredon
yup same od unit on both trannys but how do you know the problem with teh one tranny isn't IN the OD section? My last few issues were exactly there
Old Dec 12, 2012 | 07:32 PM
4x4troy's Avatar
4x4troy
I lost reverse first then all forward started slipping then it was not shifting past second and sometimes not coming out of second at all.
Old Dec 13, 2012 | 09:41 AM
volaredon's Avatar
volaredon
problems aren't in the OD; probably the front clutch pack in the main tranny... not sayin the OD doesnt have "any" wear but the front clutch pack is "high (3rd gear/direct drive) /reverse" and those are the 2 gears you are lacking
Old Dec 13, 2012 | 10:54 AM
4x4troy's Avatar
4x4troy
thanks, now I just need to get it done.
