93 dakota wont start
My fuel pump will not turn on, i replaced it, and it still will not work. I hooked up the old fuel pump directly to the battery and it works. the Wire connector to the pump gets power. I switched the relays, i cannot figure out the problem, please advise me
Welcome to DF
You may need to do a load test on the wires going to the fuel pump. You can still have power with a test light, but once you run power thru the wire you could loose some voltage. Which means you may have breakage in the wire. I will move you post to the 1st Gen Dakota section.
