Trans mount
Old Jan 11, 2013 | 07:22 PM
shadowthedakota's Avatar
shadowthedakota
Default Trans mount
anybody know how high the trans is supposed to sit about the crossmember?
my dumb@$$ forgot to keep the old one before scrapping my old trans and since they arent available t the local shops by me i have to make one up.
Old Jan 12, 2013 | 02:35 AM
inuchan187's Avatar
inuchan187
I can't answer the question, because my trans mount is shot and the driveshaft hits the parking brake cable.
You can figure it out yourself by taking a bottle jack and lifting the transmission until the driveshaft clears the parking brake cable by an inch or so.
Are you using rubber or poly for the new mount? I'm not sure how strong these transmissions are, but in general bad motor mounts and a poly or solid transmission mount can leave you with with a cracked transmission case.
Old Jan 12, 2013 | 12:17 PM
shadowthedakota
i had half of the mount that came with the transmission, which is rubber as well as the rubber bushings from where the old trans mount bolted to the crossmember. its almost 3" of the crossmember and i don't have the driveshafts in due to replacing the u-joints.
