Interchangeable years?
Old Jan 23, 2013 | 01:34 AM
Cooreman's Avatar
Cooreman
Default Interchangeable years?
I have a 1994 dakota, what years are interchangeable for parts? Mine is a 4x4. For parts I'm looking for a new dash cluster with a tach (I'm sick of the huge gas gage) a rad, steering knuckle, bumpers some little odds and ends in the interior.. Do the hub assembly's from the older first gens fit on the new ones thus changing the bolt pattern to a more commonly used 5 bolt?
Old Jan 23, 2013 | 10:55 PM
moparnut38's Avatar
moparnut38
1987-1996 are all interchangeable. I myself even thou mine is 2wd I changed the hubs so they are now 5 on 4.5 instead of 6 on 4.5. 1987-1990 had the 5 lug and 1991-1996 all had 6 lug wheels.
Old Jan 24, 2013 | 01:17 AM
Cooreman's Avatar
Cooreman
That might be the best news I've heard in a while! So the steering knuckle out of an 87-90 would fit onto my truck?
Old Jan 24, 2013 | 11:27 PM
moparnut38's Avatar
moparnut38
yes that should all be the same. The only differences between the 1987-1990 and the 1991-1996 is the front end sheet metal and the motors as the 1991-1996 are all multi port fuel injected and the 1987-1990 are throttle body fuel.
Old Jan 25, 2013 | 03:32 PM
Cooreman's Avatar
Cooreman
Okay thanks!
Old Jan 25, 2013 | 10:37 PM
moparnut38's Avatar
moparnut38
Your welcome. I am a Dakota owner and car nut and I am glad too help when ever possible. I dont know everything and always learning new things.
Old Jan 26, 2013 | 03:25 AM
Cooreman's Avatar
Cooreman
One more thing.. I have some 31x10.5 r15 tires would the fit on a 15x6 rim or is that width to small? They were on the next generation rims but with back spacing issue I can't use them.
Old Jan 26, 2013 | 10:02 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes they will fit just fine.
Old Jan 26, 2013 | 11:37 AM
Cooreman's Avatar
Cooreman
Okay! I just wasn't sure if six was too small and would create a weak bead. Is there a general rule of thumb of how small you can go
Old Jan 30, 2013 | 03:20 PM
Cooreman's Avatar
Cooreman
Another question. Sorry for asking so many. Would I have to run lower psi to counter act the ballooning effect if so how much psi am I looking at?
