Dodge dakota conversion problem
Old Mar 20, 2013 | 12:43 AM
dakotakid17's Avatar
dakotakid17
or just carb it lol and delete the crank sensor. or idk if it would work there both a 3 wire plug splice it.
Old Mar 20, 2013 | 11:39 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You will have to cut and wire in the new crank sensor onto the old harness. Cut the plug off of the old sensor and splice that onto the new sensor VERY SIMPLE..
Old Mar 20, 2013 | 08:54 PM
volaredon's Avatar
volaredon
Originally Posted by DARKELITE211
man i hope u got btr luck than i did but from the sounds of it unless u can buy a plug tht converts the auto sensor to a standard its impossible..
youre making a huge deal over nothing... I did the very swap you are wanting all I had to do was cut a pigtail from a manual trans Dakota in a yard (can be V6 even) cut yours off and solder the junkyard pigtail in... done it's only either 3 or 4 wires...
Old Mar 22, 2013 | 01:50 AM
DARKELITE211's Avatar
DARKELITE211
ok well tht solves the crank sensor problem but wat about the fuel pump i have power to it when i wire it straight but with the fuse it dnt work.. also how far away should the sensor b from the flywheel cause with the automatic one it sits rly tight on the flywheel should it b against it or how far away from it.. i dnt have the orginal bolts cause like i said everyone told me we didnt need it and come to find out we did..
Old Mar 22, 2013 | 05:59 PM
cd36's Avatar
cd36
For the fuel pump you'll have to do some tracing to see where the power ends. Do you have power to the fuse? Is the fuse good? Do you have power to the relay? Do you have power out of the relay? Is your relay getting a signal to turn on?
Old Mar 22, 2013 | 09:56 PM
DARKELITE211
the fuse is good we bought 3 thinking it was bad and idk bout the power to the relay like i said we can take a wire and put it in 2 spots where the fuse goes and it kicks on but when u put the fuse in it it dnt work..
Old Mar 24, 2013 | 10:18 AM
shadowthedakota's Avatar
shadowthedakota
just file a little bit off the crankshaft position sensor connector and it should fit right in.
Old Mar 25, 2013 | 04:25 AM
DARKELITE211
ill try it im willing to try anything right now it sux wat i thought was gonna b an easy project is turning into a head ache and its rly aggravating knowing tht many ppl have done this with no problems..
