Dodge dakota conversion problem
Old Mar 18, 2013 | 06:20 PM
DARKELITE211's Avatar
DARKELITE211
Angry Dodge dakota conversion problem
i have a 1996 dodge dakota and it was an automatic my brother -n- law and I decided to convert it to a 5 speed because the reverse went out on the automatic we got and have everything we need i believe. We have the manual transmission, flywheel, clutch, pressure plate, slave cylinder and master cylinder when we started there there was a black piece on the flexplate everyone told us it was for the overdrive well come to find out its the Crankshaft Position Sensor and we had to buy a new one when we got all the parts put in and bolted down we went to start it and we have no fire and the fuel pump isnt working unless u take a wire and run it straight.. any suggestions on how to fix this and get the truck running?
Old Mar 18, 2013 | 09:33 PM
go-part's Avatar
go-part
Former Vendor
Have you tested all of your underhood fuses?
It sounds like the one that is for the fuel pump may be blown.
Old Mar 18, 2013 | 11:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The crank position sensor is different for automatics and manual transmissions. The plugs are different too.
Old Mar 19, 2013 | 01:58 AM
DARKELITE211
fuses were checked and there good and the crankshaft sensor is there a way to get a conversion to where u can plug a standard one into it or would it b btr just to buy an automatic transmission and put back into it?
Old Mar 20, 2013 | 12:03 AM
dakotakid17's Avatar
dakotakid17
Default same 5 speed swap
hi guys my 92 v8 dak auto tranny just blew as well and i got a 95 flywheel and clutch and a nv3500 will i have a problem with the crank sensor reading that flywheel?
Old Mar 20, 2013 | 12:24 AM
DARKELITE211
man i hope u got btr luck than i did but from the sounds of it unless u can buy a plug tht converts the auto sensor to a standard its impossible..
Old Mar 20, 2013 | 12:30 AM
dakotakid17
Default crank sensor
actually i think i just solved our prob the v6 and v8 sensors are the same thank god 92 93 daks came with a v6 5 speed just get a manual sensor and you should be good.
Old Mar 20, 2013 | 12:33 AM
DARKELITE211
the plug in is different man i tried it.. it wnt plug into a motor tht had an automatic transmission in it
Old Mar 20, 2013 | 12:37 AM
dakotakid17
r u sure the sensor is your prob if so just sawp the harnes to a 94 and up
Old Mar 20, 2013 | 12:38 AM
DARKELITE211
i dnt have a wire harness for a manual transmission lol well on tht will work on a 96 dak i got one for a 91 dak and an 87 dak and there not the same..
