Rear speaker wiring has no power.
Old Mar 26, 2013 | 12:18 AM
Cooreman's Avatar
Cooreman
Default Rear speaker wiring has no power.
1994 extended cab. So the speaker wiring has no power I found this out after breaking the cover clips and hooking up my speakers to them. It did not come stock with speakers back there but has the wiring for it. I looked behind my deck and I did not see any loose wires. I've thought about just rewiring the whole set up but I want to wait till the snow is gone so I can lay the stuff out. Any one done this before is it just a unconnected wire? Let me know.
Old Mar 29, 2013 | 01:33 PM
bruteforce3's Avatar
bruteforce3
I would back track the wires that are in those locations and see where they end up. Chances are they're just not connected. You could always add to them where they stop and continue them to the back of the radio. Not the best, but if you don't have any available speaker connections on the back of the radio, you could always tap into the ones you do have. It will drop the ohms from your radio and put more of a load on the built in radio's amplifier, but it will work. Is it a "factory" radio or aftermarket?
Old Mar 29, 2013 | 08:33 PM
shadowthedakota's Avatar
shadowthedakota
Tucked up under the dash on each side of the truck are connectors for the speakers(front and rear) they might be disconnected under the dash
Old Mar 30, 2013 | 08:38 PM
Cooreman's Avatar
Cooreman
It's all factory I think I'm going to take a poke at it tonight ill let ya know how it goes. Thanks
Old Mar 30, 2013 | 11:08 PM
Cooreman's Avatar
Cooreman
Well, I took my dash and couldn't find any speaker wiring. Guess I gotta trace the damn wires after all
Old Apr 2, 2013 | 09:40 PM
cnut's Avatar
cnut
Running new wire shouldn't be that much of a pain if you have to. Let us know what you find.
Old Apr 3, 2013 | 05:25 PM
Cooreman's Avatar
Cooreman
I got the side panel off but it turns out the wires appear to run under the seats back there I don't know how to get that back piece off. I'm currently tackling the storage boxes
Old Apr 5, 2013 | 01:21 PM
Cooreman's Avatar
Cooreman
Update: I've decided to run new wire instead of tracing the old.
