Some quick questions...should be an easy answer....
Old Apr 3, 2013 | 02:29 PM
95DakotaV8's Avatar
95DakotaV8
Default Some quick questions...should be an easy answer....
As per my other random posts....I'm new to the Dodge line. I know far more about Chevys.
Anyway here goes....
1. What manual transmission options were there for the 1995 line?
2. Would the 5-speed manual for a 5.2l 318 fit behind a 5.9l 360?
3. What type of fluid should be used in such?
Thanks for all the help again guys and ladies...I'm not much of a contributor but the help I've gotten from this forum has saved me quite a few headaches.
Old Apr 3, 2013 | 02:51 PM
DakotaRT1993's Avatar
DakotaRT1993
Should be a NV3500 trans, and use synchromesh fluid.
Old Apr 3, 2013 | 02:53 PM
keilkravec's Avatar
keilkravec
or you can use the nv4500, but that requires a good bit of fab work. nv3500 is your easiest option. can be found in most newer dakotas, and rams.
Old Apr 3, 2013 | 03:46 PM
95DakotaV8's Avatar
95DakotaV8
Well since its already running and such.... Here are some follow up questions...
How can one tell when fluid is already in there?
How can one tell what transmission it is to being with?
I'm going to be replacing the clutch here soon and I know I'll need to replace the fluid too..
Old Apr 3, 2013 | 03:57 PM
DakotaRT1993
There are drain and fill plugs on the side of the trans (consult your manual). The fluid should be close to the bottom of the fill plug, put your finger in and you should be able to feel it about one knuckle below the bottom of the hole.
If your truck came with the v8 then it is an NV3500 trans.
Old Apr 3, 2013 | 04:12 PM
95DakotaV8's Avatar
95DakotaV8
The truck is kinda Lego.... Engine from a 98 Ram, seats from a Viper, rear end from a Challenger. So no owners manual.
According to the VIN it had a 318 V8 at one time. And from what I do know of the truck the transmission was never changed...even when the engine was swapped.
Old Apr 4, 2013 | 12:33 PM
DakotaRT1993
Well either way, if the trans bolted to a 318 it will bolt to a 360 just will have to change the flywheel and get the appropriate clutch kit for it when you go to replace it.
If the trans has never been changed and it came with a 318 then it is a NV3500
Old Apr 4, 2013 | 02:36 PM
95DakotaV8's Avatar
95DakotaV8
Excellent....so what fluid for a NV3500 transmission then?
Old Apr 4, 2013 | 05:03 PM
shadowthedakota's Avatar
shadowthedakota
when i filled the trans in my 93' i filled it till the fluid started dripping out. (i had swapped in the nv3500) it ran fine till the shift tower started leaking.
Old Apr 4, 2013 | 09:26 PM
moe7404's Avatar
moe7404
my friend put in a bunch of " random posts" after drinking all after noon.
