what just happened?
Old Apr 15, 2013 | 03:31 PM
Volkster13's Avatar
Volkster13
Default what just happened?
took about a 10 minute drive and came back and this happened.. all of the antifreeze is gone, leaked out, and it was smoking in an odd spot, i thought it was odd anyway.. what do you think is the cause of this.. could it be the water pump?
short video below
Old Apr 15, 2013 | 03:34 PM
matteusclement's Avatar
matteusclement
could be the pump or transmission cooling line?
Old Apr 15, 2013 | 03:58 PM
DakotaRT1993's Avatar
DakotaRT1993
It kind of looked like it might have been coming out from the thermostat housing or possibly the heater hose that connects in that same area (the one that goes to the firewall not the bypass). There is also the coolant temp sensor and the temperature switch right in that area too.
Old Apr 15, 2013 | 09:25 PM
bran1har's Avatar
bran1har
clean the area and let it dry so there is no more mess. Now add water to the cooling system, (dont worry about mixing up antifreeze for this test) and start the truck, Now go under the hood while its running and see where it's coming from. THis is the best way to find leaks.
Old Apr 19, 2013 | 10:02 AM
Volkster13's Avatar
Volkster13
tried this and it didn't leak at all at idle for about 15 mins, thinking I may have to take it for a short drive then park it and look.
Old Apr 20, 2013 | 01:56 AM
Moffman's Avatar
Moffman
If it didn't leak at idle its possible that the thermostat had to open first before the section of the cooling system leaked. Maybe thermostat housing or upper hose. Check the heater hoses too.
Old Apr 20, 2013 | 11:49 AM
Rabid21's Avatar
Rabid21
Really the best way to test your coolant system is with a pressure tester. But if you can't get it to a shop for that I would suggest warming the truck up to operating temperature then start squeezing the upper and lower hoses. This should make the leak show its ugly face. I played the eyeball game before and it is a pain in the ****, you replace one bad part and another weak part fails right after since its now the weakest link.
Old Apr 20, 2013 | 03:52 PM
cd36's Avatar
cd36
I know up here Canadian tire lends out the pressure testers. Should be a place in the states that does as well.
Old Apr 24, 2013 | 04:48 PM
Volkster13's Avatar
Volkster13
Took it to the shop they put a new water pump on and then they noticed it was leaking still. Ended up being timing chain gasket. Total for repairs 499.99 they charged an arm and a leg for labor. I feel broke now.
