BKCowGod's Dakota
Old Jun 11, 2013 | 01:09 AM
BKCowGod's Avatar
BKCowGod
Default BKCowGod's Dakota
Feel free to ignore or comment... I'm mainly doing this to keep track of all the stuff I am doing to the Dak.
1995 Dakota SLT Club Cab
Factory & Aftermarket @ time of purchase:
  • Four Wheel Drive
  • Towing Package
  • 22gal Gas Tank
  • Limited Slip Differential
  • Infinity Premium Sound
  • Automatic Transmission
  • 5.2 Liter V8
  • HD Cooling
  • Cab-height camper shell
Condition at time of purchase:
  • Purchased January 2013 for $2000
  • 145,000 miles
  • Mechanically near perfect. Radiator clogged
  • Radio malfunctioning
  • Inoperable gas gauge
  • Steering wheel worn
  • Bad lift struts on camper shell
  • Good tread on Goodyear Wrangler tires
  • Faded wheel arch flares and airdam
Goals for this vehicle:
  • 20mpg highway at 80mph
  • Comfortable for two + one (12yr old son)
  • As much performance as possible without giving up MPG or reliability
  • Reliable enough to get in, turn the key, and go to Alaska if we want
  • Should not stand out – no modifications should be visible
Attached Thumbnails BKCowGod's Dakota-209487.png   BKCowGod's Dakota-209487.png   BKCowGod's Dakota-209487.png
BKCowGod's Avatar
BKCowGod
Baseline
Whenever I purchase a vehicle, I like to get a solid baseline. My first project was simply to get it ready to upgrade. The following parts were researched extensively and chosen for their reliability, quality, longevity, and performance potential.
  • Brass terminal cap and rotor
  • STI spark plug wires (made in the USA and a lot cheaper than Magnecor)
  • MSD ignition coil
  • MSD StreetFire multispark ignition box
  • Oil change with Mobil Super 10-40 & Purolator Gold filter
  • Transmission flush
  • Replaced camper shell lift struts
Thoughts: I honestly don't think the MSD stuff adds any performance, but it does idle smoother with the multispark box than without.
Old Jun 11, 2013 | 01:10 AM
BKCowGod's Avatar
BKCowGod
Chasing the cooling system
My first big challenge was an overheating problem. I redid the entire cooling system to ensure reliability. An upcoming project will replace the clutch fan with an electric fan.
  • New fan clutch
  • New hoses
  • Factory radiator
  • 180 degree high flow thermostat
  • New coolant with Redline Water Wetter
Thoughts: With the new cooling system, I have never seen it get to the halfway point, even idling on 95deg days with the AC on full blast. The future switch to efans is simply because I can't leave well enough alone and I want to free up as much rotating mass as possible.
Old Jun 11, 2013 | 01:12 AM
BKCowGod's Avatar
BKCowGod
Breathing
The Magnum engine is plenty powerful, but I hate lost potential. The modifications below allow the engine to inhale and exhale much more efficiently. The next step in this department will be a switch to headers and a high flow cat and the Hughes intake manifold (shhh, don't tell the CARB).
  • Edelbrock hot-air intake with Edelbrock breather
  • Ported & polished throttle body
  • Aluminum intake manifold plate mod
  • Dynomax Ultra-Flo stainless exhaust
Thoughts: It is disturbingly easy to break the tires loose. I can outrun Mustangs until physics realizes I'm driving a brick. I'm not sure why I would want more, except that more is often more fun. It also sounds very dramatic when I drive in tunnels, and I enjoy scaring little old ladies when I start it.
BKCowGod's Avatar
BKCowGod
Interior
This is where I spend most of my time, and I'm used to driving slightly more expensive cars... So I'm a bit spoiled.
  • Blaupunkt San Francisco CD/iPod receiver plugged into factory Infinity amplifier & speakers
  • Wheelskins leather steering wheel cover
  • Invisible storage for my Benchmark maps, handgun, hatchet, Mag-lite, knife, and basic tools
  • Baofeng UV-5R FRS/Ham/FM/etc handheld dual band transceiver
  • TomTom GPS for on road and topo GPS apps on my old Android phone for off-road driving
Thoughts: I do love having an extended cab truck... Trying to figure out where to put the rifle out of sight. The Infinity speakers sound mighty good too, and I listen to everything from Zac Brown to the White Stripes to David Guetta. The Blaupunkt has an SD Card slot, so I just tossed a 16gb SD card full of MP3's in there.
Old Jun 11, 2013 | 11:33 AM
keilkravec's Avatar
keilkravec
If you manage to get 20mpg at 80mph, you need to share how you pull it off lol
Old Jun 11, 2013 | 11:37 AM
BKCowGod's Avatar
BKCowGod
When I first got the truck, I did a drive from Half Moon Bay to Morro Bay down Hwy 1, then back up 101 to San Francisco... the first half was winding mountain roads. Averaged a GPS-confirmed 16mpg. On the drive up, with the cruise control set at 75mph (and getting passed by 18-wheelers), I averaged 18mpg. That was with a bad radiator and no upgrades. I know it's a stretch goal, but it would be pretty cool
Old Jun 11, 2013 | 02:12 PM
keilkravec's Avatar
keilkravec
well from the looks of your upgrades, it would seem pretty possible holding about 65-70, but 80 is another question entirely since your rpm will be 1k higher if not more plus wind drag
Old Jun 11, 2013 | 03:33 PM
BKCowGod's Avatar
BKCowGod
Maybe I'm geared funny, but for me 80mph is not that much over 2000rpm...
Old Jun 11, 2013 | 08:39 PM
shadowthedakota's Avatar
shadowthedakota
might i suggest saving some money and getting exhaust manifold from a 92 or 93 v8 magnum. those 2 yrs had a less restrictive exhaust. and run a cold air intake instead of hot air intake. just my $.02
but you have really solid ideas... i like... haha
