Electrical issues in my 89 dakota sport :(
Old Jul 5, 2013 | 12:21 PM
MacDak's Avatar
MacDak
Es, chao, it's just my headlights not working.
Dave, did you look at the photo I posted above? That's the thingamabob I was talking about. Mine looked great. I've got to get me lights fixed! I'm away from me truck now, so it'll have to wait a bit.
Old Jul 6, 2013 | 09:31 AM
mopar_guy's Avatar
mopar_guy
Yes, that's the connector that I was talking about.
Old Jul 10, 2013 | 08:56 PM
ChaoticShdwMonk's Avatar
ChaoticShdwMonk
Originally Posted by mopar_guy
I have had the same issue with my '89 Dakota. My problem was corrosion in the main power feed to the lighting system. I have repaired it as follows...
Hope this helps.
Dave
Cheers mate! this fixed my issue. I took the connector off and the red wire with a white stripe was broken off the spade and just dangling there (the corrosion was bad enough that it ate through the spade).
While trying to pry out the spade it actually snapped in two. I was able to fish out the rest then cut back the wire, stripped, spliced to a new 10g wire and crimped that to a male spade connector (I had to crimp new wire on to it first then feed the wire through the top of the connector, out the bottom and splice to the old wire).
Thanks again for the help
Old Jul 11, 2013 | 10:41 PM
mopar_guy's Avatar
mopar_guy
I'm glad it worked out for you.
Dave
