Box compatibility between years
Old Jul 16, 2013 | 09:14 AM
cd36's Avatar
cd36
Default Box compatibility between years
I've started to broaden my search for a truck box, as it is tough to find one that isn't rotten around here. I have a 1991 with a short bed, and I've found a couple of good boxes online, but they say the are for a 94-96. From what I can tell there shouldn't be any difference, is anyone aware of a difference in the box between a 91-93 and 94-96? If I look at replacement side panels they say they are good from 87-96, but I'm not sure if something changed with how they mount to the frame. Thanks!
Old Jul 16, 2013 | 10:54 AM
BKCowGod's Avatar
BKCowGod
Just to clarify - by box, do you mean the actual bed of the truck, or a tool box or utility box?
Old Jul 16, 2013 | 11:44 AM
cd36's Avatar
cd36
Sorry, the truck bed itself.
Old Jul 16, 2013 | 04:12 PM
shadowthedakota's Avatar
shadowthedakota
the short beds are the same length and the long beds are 8ft. the only differece inthe short beds are the body change in 97 and the newer dakota short beds which are 5ft and 6ft depending on the cab style
Old Jul 16, 2013 | 04:51 PM
cd36's Avatar
cd36
Thanks, so the short beds from 91-96 should be the same? That is my main concern, as I see listings for entire short bed boxes being for 94-96 or 91-93, but nothing 91-96. I figured this was just the people listing it not knowing exactly what was interchangeable, but wanted to check just in case the mounts or something changed throughout the years.
Old Jul 16, 2013 | 05:30 PM
BKCowGod's Avatar
BKCowGod
Make sure the fuel filler is compatible - they did change stuff about the fuel system around those years. Also the tailgates. Check out Allpar for year-by-year changes.
http://www.allpar.com/trucks/dakota-1987.html
Old Jul 16, 2013 | 09:16 PM
shadowthedakota
the boxes are the same. the tailgates changed. the filler necks are the same(we just did a box swap on a friends short bed).
and also junkyards and stealerships have the swap-ability info for vehicles. i found this out after the window regulator went on my intrigue.
Old Jul 17, 2013 | 12:34 PM
cd36's Avatar
cd36
Thanks. The listing for the box was from a junkyard, so thats why I found it odd they only listed 94-96, I thought they would have proper info on what was interchangeable. I guess if the tailgate is different though they may list it as being for different years. Anyways thanks for the help guys, it broadens my search a little bit!
