Transfer Case????
Old Aug 6, 2013 | 01:00 PM
xkillswitchx0's Avatar
xkillswitchx0
Default Transfer Case????
I have a 1988 dakota 4x4 5speed. The tranny is bad and around here they are hard to find. I located a automatic trans but I was told the transfer case from my five speed won't work. Any help would be awesome. Also found a five speed from a 2000. Will it work
Old Aug 7, 2013 | 02:08 PM
Brian in Tucson's Avatar
Brian in Tucson
We aren't ignoring you, we just don't know. It might, tho. Or might be adaptable. Depends on what engine you have and what engine was in front of the 2000 trannie.
12 years is a long time in automotive years--if you can't figure it out by eyeballing it, I think I'd keep on looking.
I wouldn't change over to an automatic, either. That looks like it would be a pain in the butt!
Old Aug 8, 2013 | 01:31 AM
ragged89's Avatar
ragged89
I don't know whether the 2000 manual trannys will fit under older generation Daks, but I'm pretty sure the the crossmember under the trans has changed and uses a different style mount. Check overall length of any other trans you're thinking of using, as well as the rear shaft size. You'll need to match the shaft with the transfer case, and you may need to lengthen (or shorten) your driveshaft. I've done a lot of that measuring and adapting stuff lately in my own Dakota. Transfer cases haven't changed much in physical size and bolt patterns, but the speedometer and speed sensor take-offs have been removed and replaced with new electronic versions.
If you're interested I have a 5 speed from an '89 V6 4x4 that I'll let go. I have no use for it as I changed out the V6 motor and trans and put in a V8 and larger trans (the "measuring and adapting" I spoke of).
Old Aug 9, 2013 | 04:29 PM
xkillswitchx0
How much you want for the trans? My email is xkillswitchx0@gmail.com. If u wanna email me
Old Aug 9, 2013 | 10:33 PM
ragged89's Avatar
ragged89
xkillswitch, I sent you an email w/a picture of the 5 spd so you can see if it looks like yours.
Old Aug 9, 2013 | 11:23 PM
xkillswitchx0
I got the pic
Old Aug 9, 2013 | 11:24 PM
xkillswitchx0
I just bought another dakota today. Only had it about three hours and the fuel pump went out. I don't know why I love molar so much. Every one I've owned has left me on the side of the road. Lol
Old Aug 9, 2013 | 11:25 PM
xkillswitchx0
Mopar
Old Aug 10, 2013 | 12:19 PM
ragged89's Avatar
ragged89
Same here, it's an addiction I guess. What's your newest Dakota like, other than the PITA fuel pump?
Old Sep 3, 2013 | 10:05 PM
ragged89's Avatar
ragged89
Killswitch, let me know how it goes with the 5 speed. That was the first time I've shipped something that heavy! I sent you the tracking number.
