alternator engine mount broken!
Old Oct 6, 2013 | 06:30 PM
DylanB's Avatar
DylanB
Default alternator engine mount broken!
Om my engine mount for my alternator just broke, its on a 1987 dakota 4cyl 2.2l no a/c. Where can i buy another one? or how can i fix it?
Old Oct 6, 2013 | 06:49 PM
moe7404's Avatar
moe7404
fire up the welder. add a brace or two
Old Oct 6, 2013 | 10:11 PM
vhinze's Avatar
vhinze
I see two possibilities. One, find one at a junkyard. Two, take your part to a skilled heliarc welder and have them weld it up.
Incidentally, I am not familiar with the "2.2" liter engine. Are you sure you don't have the far more common 2.5 liter engine?
Old Oct 7, 2013 | 07:21 PM
DylanB's Avatar
DylanB
I brought it to a welder and they tried to do it for a couple hours but said that it wasnt strong enough and this type of metal was to hard to weld, I tried to call some junk yards but none of them have any dakota's earlier then 1990
Old Oct 7, 2013 | 07:27 PM
moe7404's Avatar
moe7404
OH i didnt see it was a 4 cyl. course you DO know that most 4 cyl engines have imbalance in the crank that cant be balanced out easily. this causes brakeage, as you can see.
Old Oct 7, 2013 | 09:41 PM
DylanB's Avatar
DylanB
Well it was fine until I broke it, I guess the guy who owned the truck before me put a different bolt in it and I didnt know it so i pride against it and broke it... It was already broken in another spot but didnt effect it, so i wasnt worried about it, till i found out you cant get them -.-
Old Oct 7, 2013 | 09:55 PM
Tom A's Avatar
Tom A
Section Moderator
Chances are, that's not a Dakota-specific part. You may have more luck finding one on a car of the same vintage with that engine. I don't know about a specific model, though. You'd have to spend some time looking.
Personally, if it were mine, I would make a new one from scratch out of steel. It doesn't look like it would be too difficult.
Old Oct 7, 2013 | 10:19 PM
DylanB's Avatar
DylanB
thanks man, ill Bring it into school and tell the welding teacher to make a new one :b
Old Oct 7, 2013 | 10:21 PM
Tom A's Avatar
Tom A
Section Moderator
Perfect!
Old Oct 8, 2013 | 10:13 AM
shadowthedakota's Avatar
shadowthedakota
and early 90's late 80's(?) fwd mopar will have one. and make sure to save the bushings as those cant be found anymore.
