Manual Transmission fluid?
Old Oct 25, 2013 | 06:17 PM
DylanB's Avatar
DylanB
Default Manual Transmission fluid?
I need some fluid for my manual tranny, Someone told me to go to advance auto and just get atf+4. Then i did research and seen i needed gear oil, Went back on exchanged it for gf-5 but then i seen that if i have brass parts i need gf-4 or what ever, Im not sure if i have brass parts in my tranny. what do you guys use/ suggest. Im tight on money right now -.-
Old Oct 25, 2013 | 06:24 PM
Tom A's Avatar
Tom A
Section Moderator
Don't use GL-5. It can harm your synchros. Use the GL-4 (assuming your transmission actually requires gear oil. The newer NV3500 takes a special fluid).
Old Oct 25, 2013 | 06:36 PM
DylanB's Avatar
DylanB
im so confused the more research i do the dumber i get, Now it says if its below 32 degrees to use 10w-30 engine oil, What should i put in it....
Old Oct 25, 2013 | 06:38 PM
Tom A's Avatar
Tom A
Section Moderator
Well, is it below 32 degrees?
Old Oct 25, 2013 | 06:41 PM
DylanB's Avatar
DylanB
I live in upstate ny, so its about that. but putting engine oil in a tranny seems weird.
Old Oct 25, 2013 | 06:43 PM
Tom A's Avatar
Tom A
Section Moderator
It's actually pretty common. I would use whatever your manual says to use for the temperatures you expect to encounter.
Old Oct 26, 2013 | 10:20 AM
marcar1993's Avatar
marcar1993
Use the proper gl rated gear oil. (I beleive its 4, whatever the manual states). I used it in my 95 and never had any issues in the extreme cold (Less than 32* down to single digits) however when you FIRST start driving in low temps its just a little goey for the first few shifts.
I wouldn't run motor oil because in the spring I wouldn't want to change it again.
Old Oct 26, 2013 | 10:30 AM
DylanB's Avatar
DylanB
Well i looked at my tranny and took some pictures, It says A535 but my book only says np2500 /ax-15 and nv3500
Its easier to see on my iphone when i zoom in but im 99.9% sure its A535
Old Oct 26, 2013 | 04:26 PM
92DakotaClub's Avatar
92DakotaClub
I believe the A535 was the np2500 .. I can double check but that's my remeberance from the day ..
Edit.. yes it is known as the Np2500 and was very common with the 2.5 :O
Last edited by 92DakotaClub; Oct 26, 2013 at 04:29 PM. Reason: verification /spelling
Old Oct 26, 2013 | 08:57 PM
DylanB's Avatar
DylanB
Should I use normal or synthetic. Is it okay If I use one quart of gl4 gear oil and 1quart of motor oil or should I just stick with the motor oil?
