Heater core
Old Nov 6, 2013 | 03:44 PM
Cooreman's Avatar
Cooreman
Default Heater core
So I gotta replace my heater core.. Any tips? What all needs to come out. It's a v8 with out ac
Old Nov 6, 2013 | 05:06 PM
Brian in Tucson's Avatar
Brian in Tucson
Get a Haynes manual.
Old Nov 6, 2013 | 05:58 PM
92DakotaClub's Avatar
92DakotaClub
is it leaking? or just no heat?
have you tried using a garden hose and backflushing if it has no heat? if leaking your boned get a manual since its a bit of work but not hard since no ac :O
Old Nov 6, 2013 | 07:01 PM
Cooreman's Avatar
Cooreman
I was going to flush it but the poor bastard before me bent the living hell out of the copper tubing so... New one it is
Old Nov 6, 2013 | 08:15 PM
92DakotaClub
LOL figures... what I did with mine was just cut the lines as they go over the motor this way I didn't touch the core itself, then just got some hose connections and clamps.. flushed rejoined with plastic nipples bene running a year like that.. the crud that came out was insane ..
but this wasn't my issue entirely, I still have problems with heat but its due to engine not going past cold, which hurts my fuel economy a lot in winter, never reaches operating temp, and no thermostat and all was changed hell even removed the mechanical fan and dosent make a difference
Old Nov 6, 2013 | 09:20 PM
Cooreman's Avatar
Cooreman
Quick question. Is the heater core under the dash near where it goes into the fire wall or does it y off into the glove box area. Is your rad leaking? Maybe a nice hole in the rad is keeping every thing nice and cool! I know my rad pisses like a siv
Old Nov 6, 2013 | 09:32 PM
Cooreman's Avatar
Cooreman
Well I'm assuming from looking at photos that's right where is sits aha
Old Nov 8, 2013 | 02:08 AM
DurdyGP's Avatar
DurdyGP
I thought my core went out cause I lost heat took It to the shop they did a pressure test to check for leaks well they the system was just clog by the lug cuz it works now
Old Nov 9, 2013 | 02:13 AM
Cooreman's Avatar
Cooreman
Well I have almost every vent out just the big black one way in the back has to come out. That's where I called er quits for the night. Couldn't really see a way to get this out. Any ideas?
