use 91 carb on a 87 dakota
As far as my research shows, the 1987 model was the only 3.9 Dakota engine that had a carb. The 1991 should be TBI.
Now I got a carb from a 1988 Chrysler 5th Ave 318 V8. It will fit the 1987. Some of the vacuum posts are different so I will have to do some figuring there. I don't know if other Dodge vehicles used a carb beyond 1988.
If the carb has that goofy small bolt pattern and it fits, I'd try it.
I found the 318 carbs are a slightly different bolt pattern than the v6s. I tried to put one on my old 3.9l and the pattern was different.
theres a factory carbd dakota sitting in the junkyard in franklin, wisconsin the guy might let go for $40. I saw it last friday when i was there for other dakota parts.
