OBD1 and the dealers computer reader
1994 Dakota 3.9L V6 OBD1
I'm trying to find out if the dealer will be able to read more info with their computer connection, than I can by checking the OBD1 flash codes.
I have spoken to two dealers across the country from each other and they were both very cagy. I was left without a direct answer, a firmly implied assertion that I should pay to have them or a Dealer "check it out" and no firm information on any other topic.
I checked some code readers advertised online and the best one I could find the Innovo 3120 would only read the OBD1 flash codes and delete them for me. I can already do that without a reader.
*As far as I know to delete a code you disconnect the negative battery cable for several minutes and when you reconnect it should be clear of problem codes. You'll get a 12 which means the battery has been disconnected within the last 50 starts and a 55 which means it is done reading codes.
No idea if dealers can do this there is a plug coming off the pcm to check codes I'm pretty sure you can go to almost any shop and have them check it. And you're right on dissconecting the battery. It resets the pcm and is good to do after changing sensors or doing tune ups so it has something fresh to go by and canake the ajustments needed.
well its been a while but from what I remember with o'l SNAP ON tools scanner and older 90's dodge vehicles , it was able to read a lot of info
The dealer and most after market scan tools (not code readers) like Snap-on and OTC can read more than just codes, they can read data. My Snap-on Solus Pro for example can read data. Because I could read data I could see the fuel trims pegged lean after I did my 5.9 swap in my '94 Dakota using the 5.2 computer. I also use my Solus Pro to read data on my '88 OBD I turbo-charged Caravan when I tune it. If you want to read data, your best bet would be to look for an used OTC 4000e on Craig's list
I've seen the OTC 4000e's between $100 and $300. Got a link for me to check.
I was figuring the manuals would explain the numbers and I would be able to ask here. Here is the link it has several extra cartridges listed and he just responded saying it had an OBD1 cartridge.
http://sfbay.craigslist.org/pen/tls/4182916639.html
Trending Topics
That is the scan tool you want as a do it yourselfer and a weekend mechanic. I want to pick one of those up so I can leave it in my turbo-van when I'm tuning. If my van gets broken into, I'd rather lose a $150 scan tool than a $3500 one.
Those manuals won't have it either. You can ask here, someone might know the answer to what your asking but a lot of it comes down to experience which most weekend mechanics don't have. A scan tool is nothing more than a sophisticated test light. It's not the be all, end all to vehicle diagnosis. If you test a circuit and a test light lights or doesn't light, if you don't know or are not familiar with that circuit, the data you are seeing is useless. Just like a trouble code doesn't tell you what the problem is. It tells you WHERE to start looking and testing.
