Burning oil
So what accounts for using a quart of oil a month? Do you see any evidence of massive leakage?
REASON NUMBER 1: its a friggen Dodge
depends on how much in town stop and go/idle he does
how much milage he does a month.. if hes doing 3-4000 miles a month that's not unusual... but if 3-400 a month well I would be checking that plenum gasket.. I just went that route not long ago
I have a leak at the pan plug. I am gonna re-tap and replace the plug. I drive about 800-900 miles a month, some months more because I have to travel for work sometimes. Usually every other month(adds about 1200 miles when I travel for work. New York to North Carolina and back). I add oil about once a month but not on the dot every month. Only when it gets below the safe zone on the dipstick. It might be the 5th this month but then the 25th the next, and not always a full quart(sometimes only 3/4, sometimes half). The pan plug I would imagine is the culprit for most of the oil lose but no way to really measure how much I am losing that way. I could park it and put a pan under it but I would only get half what I am looking for as not running equals no pressure. As a matter of fact I added lucas oil treatment to it with one of the oil changes and didn't have to add a quart until I did the next oil change without it. I have only owned the truck about 4 months and it was under maintained by the previous owner and sat for some time before I bought it(hence expecting it to be gaskets from being dry for so long). For the first three months I did an oil change almost every 45 days to work some lubrication back into it. That's 3 changes in 3 months. I just started to notice things since, because I have finally had the time to really get into working on it. Thought I had a pressure problem at first but it turned out to be a faulty sending unit. Oil can would flicker, but wasn't losing pressure on the actual gauge and no change in the motor. Along with the plug issue I am going to change out the seals, rings, and plenum gasket, and go from there. Remember it is a '91 though. I expect some leakage/lose until I can get everything changed out. The puff of smoke when I opened the oil fill is what concerns me(not a big plume, but enough to see it). It happened right after I took about a hundred mile trip. That is my first priority. Also I want to let you both know I appreciate all the advice I have received from both of you.
the puff isn't uncommon specially if it was just or shortly after running, its a sign the pcv is toast tho.. and not venting properly but u said that's on your list..
my truck after the plenum was changed 92 318 MAGNUM I still use roughly 1/2 to 3/4 between changes which was better then fill up the oil and check the gas :O lol
well with plenum you will see a great draw in oil.... I was going a litre a week ... and I only put 2000 miles a year on the truck so not driven a lot also fuel mileage will go down drastically you should be around the 15~ mark anything below 10 id go for the plenum..lol there is also a test you can do for plenum leak.. just cant find it atm..
Update: Got into the truck a little this morning and I swapped out the 160 thermostat for the 195 hi-flo. Cleaned the aic(pretty rough shape). Adjusted rear brakes. Working great now.
Changed the pcv valve and grommet. Here is a pic of the old one:
Nasty little thing.
Checked the spark plugs for any evidence of faulty rings and was glad to see none. Here is a pic of the worst plug. Did also notice need new ones, lol. No idea how long these have been in there.
I did find however that I have blowouts on the plenum.
Looks like that is next.
Nasty little thing.
PCV looked harsh dude....
Plugs look like they are burning hot and lean condition.. not rich :O
quick plenum issue video:
